"Service Engine Soon" Light coming on
Old Dec 1, 2002 | 09:30 PM
rubman's Avatar
"Servive Engine Soon" light has been coming on since I replaced my plugs at 61K. Strange thing is, I've been getting 25MPG since the change. Anyone? Is there anything in particular that I need to do to turn the light off? I've disconnected the battery for up to several hours and no result. I'm afraid that I might need to taking it to a dealer. Any info would help. Thanx. I'm going to leave it disconnected overnight.
Old Dec 2, 2002 | 05:45 AM
UMD_MaxSE's Avatar
Got Bent?
read the code...
Old Dec 2, 2002 | 05:59 AM
hubbabubba's Avatar
Need Help with Service Light Also
On my 3 week old 03 SE, I just notice that the engine service light is faintly on. During the day, when I am outside I cannot see the faint yellow light AT ALL. But at night, I see it a little. It's not the bright yellow light when you start the car, it seems to a very light glow.
I don't remember seeing it before (it's possible that I just missed it though), so I don't know what's going on. Can you please tell me if that glow is normal, and if this is something I need to worry about.
Thanks for your help!!
Old Dec 2, 2002 | 06:04 AM
LouE37's Avatar
Re: "Service Engine Soon" Light coming on
Disconnect the battery overnight then reconnect in the morning...works like a charm!
lcf's Avatar
lcf
Re: Need Help with Service Light Also
Many others have this same problem. A search might yield some good results.
Good luck!
Old Dec 2, 2002 | 06:32 AM
spta97's Avatar
Re: Re: Need Help with Service Light Also
Good luck!
Yea, search for "Dim SES light" or "Dim check engine light". I had an interesting thing happen to me on mine. My SES light did the dim thing but I just ignored it. Over the weekend my door ajar light did the same thing!
Can anyone who had this replaced tell me what they do to take out the cluster? I'm worried that they might mess up my neon, bass boost ****, and stereo if I bring it in to have it fixed.
Thanks!
Old Dec 2, 2002 | 10:43 AM
skyjay617's Avatar
believe me....it's your O2 sensor!!
Old Dec 3, 2002 | 09:42 PM
Teser's Avatar
Once again - go to autozone (on www.autozone.com use store locator) and get free diagnostics. They will tell you your OBDII codes and then you should know what the problem is.
Good luck
Old Dec 3, 2002 | 09:44 PM
rubman's Avatar
Re: Re: "Service Engine Soon" Light coming on
Good luck
Thanx for the suggestion, hadn't even thought about that. Will do that this weekend.
Old Dec 17, 2002 | 05:20 PM
flysiu's Avatar
Perhaps a dumb question.....but where is the hook-up for the diagnostics? I took my car to AutoZone tonight and they could not locate a hook-up location. I took a quick look and did not see it either. I am familiar with American vehicle hook-ups...but have never needed to check the Nissan.
Good luck
Old Dec 17, 2002 | 07:06 PM
Teser's Avatar
Re: Re: Re: "Service Engine Soon" Light coming on
It should be under the steering wheel, above the pedals. Get a flash light and you'll find it.
good luck.
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
yat70458
Aug 3, 2015 01:16 PM
