Belt Squeal Question
Old Dec 2, 2002 | 12:41 PM
MaximaJohnny's Avatar
Ok I had a belt replaced on my max recently and its been squealing every since. The mechanic adjusted it saying that it should be fine but it still does it. It does it mostly when Iturn the wheel hard and it does it REALLY bad when the car is cold. Now this is just my opinion but the mechanic telling me to just tighten it up cause its too loose but it makes sense to me the the belt is actually too TIGHT. Think about it, it does it badly when its cold meaning the belt is tighter when its cold so it makes the noise but when the car warms up it doesnt do it at all. Just my guess but i think that it might actually be too tight what do u think??
Old Dec 2, 2002 | 12:50 PM
Sudesh's Avatar
Re: Belt Squeal Question
If the belt is new and squeling, it's loose. If you can flip the belt over with your hand pretty easily, then it's loose. Tighten it first and see how much it helps.
Old Dec 2, 2002 | 12:57 PM
ShOwMaX
if it squeals when you are turning then it sounds like the power steering belt. Mine use to do that too when you turn all the way to the left or right! you should also check your power steering fluid. Make sure theres enough there.
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
homewrecker
Sep 24, 2015 07:01 PM
