Lowering springs and camber kit
I just put Maxspeeds on, and my friend told me that I should get a camber kit so the tires won't wear out unevenly. Anyone else have this kit?
Originally posted by johnny2kgle
It would not hurt to get camber bolts (Eibach) for an adjustment +/- 1 degree, cost $50.00 from tirerack or sw autoworks. You do not need camber plates (Stillen $300.00) if the drop is 2" or less.
You can get camber bolts from your local speed shop for about 20 bucks.
You can even use a high strength bolt from you local hardware store, smaller in diameter then your OEM bolt to give you more adjustment in the lower mount.
Total cost.... about 2 bucks.
Originally posted by njmaxseltd
Why buy the bolts if you don't need them? His camber will be fine with Maxspeed springs. $50 bucks is way to much for 2 bolts too.
imported_Nismo_max
Feb 17, 2016 03:39 AM
BiggRoosta
Sep 23, 2015 08:53 AM
