crazy tach at low speed -->new car?
My max has a problem at very low speed (<5mph)or when stops at a light. The tachometer could jump between 1100rpm down to 400rpm and the whole car is shaking! I am afaid it will expire some time! THis only happens when gas pedal is not presssed. Once I step on the gas, every thing looks fine. I also have a check list, pleas pick what you think it is most likely:
1. idle speed setting messed up. ( Please tell me how to reset.)
2. The rubber pipe between air filter box and intake manifold is cracked.
3. Bad sensor?
4. EGR/PCV valve?
This problem has been so annoying that I want to trade it in for a new Acura TL if prob not fixed. Which gen of max do you think is comparable to 2003 TL performance-wise?
3. Bad sensor?
4. EGR/PCV valve?
Re: crazy tach at low speed -->new car?
3. Bad sensor?
4. EGR/PCV valve?
3. Bad sensor?
4. EGR/PCV valve?
Re: Eric, could you give a little detail
about where the bushings are and how to fix them?
http://forums.maxima.org/showthread....=shift+bushing
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
