PCV valve hose question
Old Dec 11, 2002 | 04:13 PM
I30tMikeD's Avatar
I replaced my PCV valve today. The 3" hose that connects to the valve had a small tear in the end and I made it worse while disconnecting it. I decided to replace the hose while replacing the valve. I went to PepBoys to get a new hose and they had no vaccume line hose, only fuel line hose. Will using fuel line hose be a problem? It seems fine so far.
Old Dec 11, 2002 | 04:47 PM
MIXXMAX's Avatar
I think you should be fine. The fuel line hose just has a better construction build to it for high pressurized fuel. As far as the PCV valve, there is only air passing thru it, so you should be fine.
slimer's Avatar
A couple of Blaxxx's? Lawls.
Re: PCV valve hose question
no, fuel line hose is ok, its just firmer. it has more belts than a regular vacuum hose. I had this problem when i replaced my girlfirend's pcv hose when i installed a cai on her tiburon. You shouldn't have any problems.
Siler
Old Dec 11, 2002 | 05:13 PM
I30tMikeD's Avatar
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:09 PM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
