I had to use fire to modify my car
Old Dec 15, 2002 | 09:08 PM
ericdwong's Avatar
Ive been so lazy lately my car is still not back on the road. Anyway I got unlazy and decided to do my control arms which I had pulled off the car a while ago. I first tried a dremel and cutting disc, but that proved to make a huge rubber smoke show. My mom pulled up in the driveway and from the smell asked if I was doing burnouts.
the rear bushings werent hard to get off, just took some brute force. I used a screw driver and beat off with a hammer till the rubber slid right off. The front cylinder bushings were a bit more difficult. I wound up taking a road flare and directing the flame into the hole, so the metal bushing heated up and then I beated it out witha hammer. Then I took a hacksaw, inserted it through the cylinder and hacksawed the outer part of the bushing. Then I took a screwdriver and beat on it until the metal seperated and I was able to get the cylinder out. Now I have to put rear main seal back in, the upper and lower oil pans, the clutch the trany and the suspension and my car will drive once again.
Old Dec 15, 2002 | 09:40 PM
nadir_s's Avatar
vicodin ... gift of life
Re: I had to use fire to modify my car
you are nuts
i wish i had ure knowledge and experience tho, then i could fix my own max!
Old Dec 15, 2002 | 10:05 PM
SWEETSOUND2001's Avatar
Are you still keeping the car?
Old Dec 15, 2002 | 10:38 PM
ToYLeT902's Avatar
JET Speed Lab
i am guessing you have a compressor at home with air tools?
Old Dec 16, 2002 | 05:21 AM
njmaxseltd's Avatar
Next time drop them off at your local mechanic to have the old bushings pressed out and the new ones pressed in. Even a tranny shop has presses.
You could have been home on the couch with your lazy a$$ having a beer while they did the work for about 10 bucks!
Old Dec 16, 2002 | 06:05 AM
Lime's Avatar
No shop charges $10 for anything anymore. I think the minimum charge is like $75 heh.
Whitemax's Avatar
Disco Biscuit
Ya but then he wouldnt have had an excuse to turn the torch on, and play with fire.
Old Dec 16, 2002 | 06:39 AM
Frezny's Avatar
I used a screw driver and beat off with a hammer till the rubber slid right off...
now that sound painful
Old Dec 16, 2002 | 07:00 AM
ericdwong's Avatar
My friend has a press. The control arms are at a wierd angle that you cant get the correct angle into the unit. Oh well this job actually isnt as hard as many people make it out to sound. I just hope the NVH doesnt increase exponentially with these bushings.
Old Dec 16, 2002 | 10:11 AM
RapidMax's Avatar
Re: Re: I had to use fire to modify my car
Old Dec 16, 2002 | 12:23 PM
Ramius83
Eric, you still, to this day, amaze me with what you do/know.....
Old Dec 16, 2002 | 01:30 PM
MAXIN's Avatar
Confessions of a TRUE backyard mechanic....
mucho props my man...
Old Dec 16, 2002 | 01:54 PM
Jeff92se's Avatar
I'm needing a caw
Old Dec 16, 2002 | 05:50 PM
BLaZin 2k MaX's Avatar
Your sig pic of you burning out is bad @$$.
Old Dec 16, 2002 | 05:58 PM
2DMax's Avatar
I've been using road salt for my latest mods !
Old Dec 18, 2002 | 07:51 PM
ericdwong's Avatar
Pics!
http://mywebpages.comcast.net/ewong61/max/DSCF0091.JPG
http://mywebpages.comcast.net/ewong61/max/DSCF0092.JPG
Old Dec 18, 2002 | 07:59 PM
Rufus's Avatar
thats awsome how you accomplished your mod! are you the burnout on maximafourms.com? how did you do that burnout and what mods did you have when you did it???
Old Dec 19, 2002 | 08:13 AM
ericdwong's Avatar
Umm whats maxima forums.com? I have a few burnouts on video, not sure if it was me though.
halfpol
Oct 17, 2022 12:16 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
mpbclutch33
Aug 25, 2015 06:23 AM
halfpol
Aug 5, 2015 08:24 PM
