Anyone install air horns on their 3rd gen?
after a quick little search...
After searching for "air horn" I found 76 threads. Anyways I found a link in one of them. http://integra.vtec.net/geeser/megamax/horns.html
IMO, airhorns make our Max sound like a clown car. but whatever floats your boat.
the horns on our car are located on the center support bracket right behind the grille.. they're about 2.5" round.
the rest of the instructions should come with the horns.. if you can't figure it out from there, you probably shouldn't be trying to install it yourself. (no offense intended, but they're a pretty simple job)
Originally posted by 1FasMax
hey how much are these air horns, what make and model number should I get, I can we get instructions on how to install them
Matt
Matt
Thanks for the info, I'm not great with cars, but I want to find out what the job entails before I take it on, my uncle will be helping me, and he's done everything to his s/ced Mustang. I think I am in good hands, with him and you guys at my side
air horns
i hope there Hella at least..... so hear we go.... u should have a relay supplies with ur set.... look at the relay at the terminals... u will see 85 86 87 30.... u will be connecting wires to them also the connections on the air horn should show "+" and "-" ok from ur factory horn wire..tap another wire to it on the other end of the wire gets connected to 85 of the relay terminal u must use wire crimps or soldier it..... now with another wire connect one side to 86 and the other side to ground of the car pls u a ring terminal....the next wire the one side u connect to 87 terminal and the other side u connect to a fuse holder and place a 20 amp fuse u connect straight to the battery... now with another wire u connect the one side to terminal 30 the other side of that wire goes to the air horns "+" ternimal... u ground the "-" terminal and there u go i think the hoses self explanitory how u connect it to the chasis make brakets or use zip ties... it very easy just take ur time
items need
wire crimper/stripper
4 speaker terminals blue
about 6 feet of 12 ga wire
2 ring terminals blue
a fuse holder
2 blue butt connectors
20 amp fuse glass or the red one (depends on the fuse holder u get)
honk that horn and ur all done
the average life span on a air horn is like 1 1/2 yrs
depends if ur horn happy too
items need
a fuse holder
Re: air horns
Mine only lasted about 3 months... (the first set)
The second set was a different brand and lasted a little longer, the 3rd set only lasted about 2 weeks because then my 90SE got totaled....I should put some on my Z for ****z and giggles.
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
