What's the benefit of having an oil filter heat sink?
Old Dec 23, 2002 | 11:29 PM
pinakbet's Avatar
Are there detrimental effects of having an oil filter heat sink?
Here's a picture of one
Happy Holidays
Old Dec 24, 2002 | 04:21 AM
wdave's Avatar
Unless you live in a very cold climate the cooler would be a fine idea. For really severe conditions an oil radiator would be even better. Cooling the oil extends it's life and takes some load off the engine cooling system. The problem is to find one of those sleeves to fit the tiny Max filter (the fit needs to be good for it to work).
Old Dec 24, 2002 | 07:47 AM
iwannabmw's Avatar
Ya gotta love BMP The theory is sound, but if you're really having problems with oil temp, install a cooler. What I really love is that want $30 for it and list the M20 as an application for it. This engine has the oil filter running 2 inches from the exhaust manifold. If you were to use this product you'd probably end up adding heat into that motor
Pinkabet, if you're really worried about oil temp, install a cooler. There are some out there that have bypass valves so you can use them in cold climates, but if you have to worry about cold in HI.......
Old Dec 24, 2002 | 12:10 PM
Eric L.'s Avatar
The engine in your vehicle was built to function correctly without problems with the stock components. If you are really worried about the oil getting too hot and causing component wear (never seen proof of this in an unmodified engine) then install an inline oil cooler (kind of a small radiator to circulate coolant through). A heat sink for the oil filter would help minimally at best, I would imagine.
Old Dec 24, 2002 | 06:53 PM
pinakbet's Avatar
Thanks for the replies fellas...
I was wondering what the deal was w/ these things. Not that I'd try it. As it is, Honolulu is tiny, and my commutes rarely exceed 30 minutes. The engine doesn't really warm up by the time I get to work or get home. Also, MPG went from suck to blow when my job moved closer to home.
bp
Old Dec 25, 2002 | 09:32 AM
VMaximus02's Avatar
Re: What's the benefit of having an oil filter heat sink?
Happy Holidays
Here's another one, cheaper too!
http://www.jcwhitney.com/item.jhtml?...=19936&BQ=jcw2
Fbana41
Aug 29, 2016 12:18 PM
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
sdotcarter
Sep 2, 2015 09:53 PM
