where did my gauge lights go?
well idk wut happened al of a sudden my guage lights just shut off on me, then like half an hour later they turned on for a lil bit. i checked all fuses...no problems there. i found out if u put the tilt on the steering wheel all the way up the lights come back on. im thiknin its a bad ground somewhere? any ideas? im gonna check my chiltons to see where the wiring is maybe i can do this on my own
~mike
~mike
Re: where did my gauge lights go?
~mike
~mike
S
Re: Re: where did my gauge lights go?
yea its just the lights. the funny thing is sometimes u can put the tilt down and they will stay on for a few min then cut off. im gonna check all the harnesses under the dash tomorrow. this sucks because i do alot of night driving. good point about the lights goin bad tho i kno i can pull em outta my old max.. well i hope its just a loose connection.
~mike
~mike
Re: Re: Re: where did my gauge lights go?
~mike
~mike
S
ok well heres a question wut exactly do i have to do to get to the bulbs? because where i am i dont have a lpace to pull the whole dash apart and set it out side the car. if it is a lil bit of work im sure i can jus set things in the seats for the time being. also how long do u think it would take to do it? thanx
~mike
~mike
~mike
~mike
S
well i did that yesterday and found that the problem wasnt behind the dash/inst. panel tho however i saw a cluster of wires heading towards the top side of my steering wheel, whle the panel was out i figured to reach back and wiggle it a bit and then my lights flickered on and off. so i found the problem. put everything back together traced the cluster of wires to the underside of the steering wheel, to where all the switches and levers are on the steering wheel. i pulledth cover off and there it was. someone had spliced the wire then did a ****ty job trying to fix it with a butt splice, so i just added a bit of wire to give a lil slack and a good connection sealed it up and everything works now. thanx for the help.
~mike
~mike
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
