260-270 WHP NA? Heres is the missing link(new 2004 oem max part)
Old Jan 6, 2003 | 07:02 PM
emax02's Avatar
Above is a pic of the 2004 maxima bay, it's hard to see whats under the cover but heres what nissan has listed.
They have the motor specs as follows:
Engine features include electronic throttle, silent timing chain, microfinished camshaft and crankshaft surfaces, molybdenum coated pistons, resin intake collector ,digital knock control system, cross flow coolant pattern and higher capacity muffler.
As you can see the intake manifold is indeed new, it no longer has the very poorly designed variable intake manifold. It now incorparates a resin intake collector . This may sound cheesy to some but it is(well should be) a big improvement over the 2002-2003 variable intake manifold. The 350Z and G35 show a 30 WHP gain using there very well designed intake manifold(thats where there extra power comes from).
So what does all this mean? It means I have a new project comming up in may With the addition of this manifold, OBX headers, Apexi S-AFC and iridium spark plugs I hope to see around 270 WHP NA and 250 WTQ. Don't beleive me? You will see.
Old Jan 6, 2003 | 07:07 PM
Y2KSESteve's Avatar
Should be awesome!!
Old Jan 6, 2003 | 07:08 PM
KL99SEA's Avatar
You the Man!!!!!!!!!!!!!!!!!!!! Sounds good.
Old Jan 6, 2003 | 07:41 PM
MichaelAE's Avatar
The great thing is that once you have collected all that resin in your intake...you will be able to take samples to Jurassic Park and potentially grow a T-Rex or Raptor.
Old Jan 6, 2003 | 08:25 PM
slickrick's Avatar
how much will all of this cost?
Old Jan 6, 2003 | 08:49 PM
emax02's Avatar
$500-800 at a discont, it depends if certain pieces match up or not.
Old Jan 6, 2003 | 09:21 PM
03BlkSETE's Avatar
Sounds great. While you're at can you find a way to swap out the the 4 speed auto tranny for the the new 5 speed auto. I know, I know, you have a manual.
Good luck on the new intake project.
Old Jan 6, 2003 | 09:30 PM
emax02's Avatar
A new ECU and new tranny should do the trick for you. I'm not trying it
I have been looking around on www.nissannews.com and I found the following quote on there.
Maxima’s legendary performance continues in 2004 with the continued use of the award-winning VQ 3.5-liter engine. The VQ engine series has been recognized as one of the "Ten Best Engines" by Ward’s Auto World magazine for eight consecutive years. The DOHC 24-valve V6 has been refined to produce 260-plus horsepower and 250-plus lb-ft torque. The increase in power and torque was created, in part, by modifying the intake duct and exhaust muffler, thus improving the intake/exhaust flow ratio. An equal-length tuned exhaust with a high capacity muffler adds power and gives Maxima a quiet, yet strong, sound – hinting at its performance capabilities.
Old Jan 6, 2003 | 09:49 PM
chinaonnitrous1's Avatar
Were behind ya e-man....im learnin alot from ya..lets keep the HP commin..hahha ........hmm i wonder whats in the way of that battery being mounted the 2k2 way..mebby a big air collector over in that corner...
Old Jan 6, 2003 | 09:52 PM
AgisAbatzoglou's Avatar
What about the weight of the 04, I heard at least 3400 lbs.
Old Jan 6, 2003 | 10:11 PM
emax02's Avatar
Keep in mind the 2004 max is on a altima platform, and if you look at a altima the battery is moved in the same way. I beleive they mounted a fuse box in that area, not sure though...
AgisAbatzoglou, sorry but what does the 2004's maxima weight have to do with this?
Old Jan 6, 2003 | 10:18 PM
CBass69187's Avatar
270whp
Emax, you are the man! How in the world do you think of this stuff? Looks like I am gonna copy you again if this works.
Russ
Old Jan 6, 2003 | 11:10 PM
TimW's Avatar
The silent but deadly Moderator
heh, throw in that new silent timing chain in there while youre at it.. How is that a new feature? You cant get Nissan to acknowledge that the 02's are noisy, but they call that a feature in the 04's
Old Jan 6, 2003 | 11:26 PM
K Pazzo 6's Avatar
there's nothing u wont try w/ your 2k2....I bet you'll be the first turbocharged 2k2
Old Jan 7, 2003 | 01:53 AM
chi02max's Avatar
quoted by emax,
the g35 has the microfinished camshaft and crankshaft surfaces and molybdenum coated pistons, so does the 350z. i don't think the 2k2-2k3 has them... err maybe they do. i hope your project works. i will do the same. hehe.. sorry for copying you. =) while your doin that, might as well put the timing chain on to eh? hehe. btw, does that make it quieter?
Old Jan 7, 2003 | 04:28 AM
BigDogJonx's Avatar
270whp? NO way...... 255-260whp maybe.... Ethan, I would really have to take a look at the intake manifold but dont think that is going to eqivalate to 10whp. That is too much, that is damn near Ypipe territory.
Dixit
Old Jan 7, 2003 | 04:50 AM
mzmtg's Avatar
Minister of Silly Walks
All VQs have those features, from 1995 on.
Old Jan 7, 2003 | 05:15 AM
wild willy's Avatar
[QUOTE]Originally posted by emax95
[B]
Does that now make the Maxima the Altima's fat young brother
Old Jan 7, 2003 | 07:43 AM
emax02's Avatar
Dixit
The Z dynoes at 235-240 WHP stock. The extra power comes mostly from the intake manifold. So a 10 HP gain fom a good flowing intake is a understatement, try about 30.
Old Jan 7, 2003 | 07:55 AM
BigDogJonx's Avatar
Porting the intake would probably be better... I dont think the intake manifold from the Max and Z is that different. I need to take a look at this.
Dixit
Old Jan 7, 2003 | 08:06 AM
wild willy's Avatar
I think 30 is a big overstatement...No way
Old Jan 7, 2003 | 02:07 PM
BJGemini's Avatar
MMMMMMMMM
6th gen power + 5th gen looks = Are we approaching icon status yet, EMax?
B
Old Jan 7, 2003 | 02:10 PM
Jeff92se's Avatar
I'm needing a caw
I don't see how the previous intake manifolds could be so inefficent that they could find 20-30hp just be redesigning it. Don't get me wrong ewok, I would love to be proven wrong. Good luck.
Old Jan 7, 2003 | 02:34 PM
Ollie's Avatar
I noticed that not so cute MAF sensor in the picture.
Old Jan 7, 2003 | 04:59 PM
emax02's Avatar
Dixit
You dont' think the Z manifold is to differnet huh? Ok
Well, this speaks for it's self.
And
And for all you nay sayers, explain to me why the 350Z has 40 more WHP stock over the max, come on let's here it? lol. Please dont say cause there motor is better because it's identical, and don't say it's the "exhaust". The 350Z gains 20 WHP from a Y-pipe and 11 from a nismo exhaust. So whats left I ask, think it;s the headers? No thats right headers dont do jack you all say? So I ask why exatly does the Z breath so much better then the max I ask? Simple, think about it...
And if the max new manifold does not pan out to be good I am going to fininsh my 350Z manifold conversion, infact I might get right to it now.
Old Jan 7, 2003 | 05:07 PM
Jeff92se's Avatar
I'm needing a caw
Hey, I hope it works. Not trying to discourage you at all brah!
Old Jan 7, 2003 | 05:08 PM
BioMaxDDS's Avatar
And
don't need to prove anything to those non believers.....cuz most of us think u r da man
Old Jan 7, 2003 | 05:09 PM
92 SE-R 02 SE
im with emax...find more HP for the 02-03 peeps!!
Old Jan 7, 2003 | 06:16 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
10hp ethan
Old Jan 7, 2003 | 07:32 PM
Larrio's Avatar
The Definitive AE Master
I believe the numbers that emax says can be put down with the 2k4 intake manifold... but I was wondering if the 350z has slightly different internals that contribute to the extra 30-40 whp ALONG WITH the different manifold
Old Jan 7, 2003 | 07:45 PM
BigDogJonx's Avatar
Emax you missing the point, im not putting you down, just saying dont set the standards too high. I dont think an intake manifold alone is going to give you 30whp-40whp. What you misunderstood is that I dont think the intake can be that bad from the 2k2 to a 2k4. The biggest gainer on intakes in the range of 30-40whp came from the MEVI. But in our case the 2k2 and 2k4 and Z all do that already. So even if we ported the max intake manifold to be smooth as hell and make it the best flowing intake ever, I cant see getting anymore than 10whp. The best porting job would have to be better than the Z intake manifold or the 2k4 manifold anyday.
Like I said, Im not putting you hopes down. I think the Z also gets it power from different compression ratios and other small nick nacks. I think exhaust differences are like 10-15whp tops from 2k2 max and Z.
I'd still consider porting the intake manifold and headers if you want to hit up high #s.
Dixit
Old Jan 7, 2003 | 08:24 PM
emax02's Avatar
[QUOTE]Originally posted by BigDogJonx
[B]
I know your not putting me down Dixit, you just don't agree with what I'm saying and that's jsut fine.
Ok and I will again point out the fact that the Z puts down much more power then the max. Heres my question again, where is the extra 40 WHP comming from? That's RWHP mind you, typicly a FWD drive train is more efficient.
Compare apples to appleas here, what does a MEVI have to do with this? Differnt applications can and will yeild drasticly different results.
Do what exactly? You lost me here.
Why would porting a poorly designed intake manifold make it "the best flowing intake ever"? I fail to see the logic here. Intake designes vary greatly and simply polishing a poorly designed intake will yeild little to no results. By no means does polishing a bad intake make a good intake. If this logic held true why do people buy a MEVI? Why do many, MANY aftermarket companys sell better flowing intake manifolds?
This notion is apsurd and I am shocked your even saying this, you really have a lot of research to do.
The Z and the max share a 10:3:1 compression ration, AKA the same. And there are no nick nack differences, this has been proven many times now. The are identical.
Like I said before the Z has shown nice HP gains from after market exhaust systems, just like the max. So the extra power the Z makes does not reside here.
You over rate porting and polishing way to much. You can port and polish the hell out of any crappy piece and it's not going to make it a good piece.
Old Jan 7, 2003 | 08:28 PM
freeze2k2's Avatar
MMMMMMMM resin.......wheres my lighter!
Old Jan 8, 2003 | 06:04 AM
BigDogJonx's Avatar
Alright EMAX, you win...... Like I said I wasnt knocking on you. Maybe at the same time Im trying to understand this logic as well.
Dixit
Old Jan 8, 2003 | 06:39 AM
2002Maxxxima's Avatar
And
I'd like to see you finish that project. You bought all that stuff and now it's just sitting there. Get that shiz on there and go dyno for petes sake.
You have some very innovative ideas, and it seems you have the cash flow to do some testing. We all appreciate you being out there on the front line for us.
Old Jan 8, 2003 | 08:19 AM
Max_Gator's Avatar
FWIW - when I had the VIAS problem on my 2k and the intake was not changing over at 5k, I dyno'd the car and compared it to the earlier stock dyno I had done.
The result was a loss of about 35-40 HP TO THE GROUND at redline simply from a failure of the intake to switch over.
So, clearly the intake collector can account for the difference.
The only question I have is whether changes were made to the ECU maps as a result of the change in collector/air flow to allow the car to better utilize the change.
Old Jan 8, 2003 | 09:30 AM
slickrick's Avatar
i like the gator flag.
Old Jan 8, 2003 | 12:05 PM
quansung 2's Avatar
hey emax,when are you going to dyno your car again?
Old Jan 8, 2003 | 12:38 PM
Padsy's Avatar
Boost.....
Old Jan 8, 2003 | 02:45 PM
emax02's Avatar
I have a Aexi S-AFC on order
