Hey emax95
Old Sep 11, 2000 | 03:45 AM
josh95se's Avatar
When you installed your newer style grill, did you do the bumper also? If not, how did you make it fit?
Thanks..
Josh
Old Sep 11, 2000 | 10:41 AM
emax02's Avatar
Grill Info
I originally bought just the grill and swapped it with the old one,It did not fit quite right though because the grill mounts to the headlight,and It is a little different mount in the 95 then in the 97.So what I did at first was I actually shaved about 2 millimeters off the bottum of the grill and then positioned the grill {with the hood up}to fit in snug with the front end Irilles 2 holes into the bottom left and right of the grill into the bumper.It fit pretty good after that.If you want to avoid all that trouble then just ordor 97 headlights too,it will fit perfect with the combonation of the two.You can check http://www.autodirectsave.com,that is were I got my 2 headlights for $224 shipped.About the bumper It has nothing to do with the grill or headlights so there is no need to buy that to.
Good luck it was worth every $$.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
jds22
Sep 29, 2015 02:03 PM
Marc2theMax
Sep 28, 2015 08:13 AM
zmcneely13
Sep 26, 2015 02:26 PM
