for 2k2 2k3 owners, if you need a new MAF...
Old Sep 28, 2015 | 06:04 AM
TallTom's Avatar
Hey, hopefully this will help someone out. I noticed a loss in power and decided to swap out my MAF. I already did the 2k1 MAF + thermistor swap two years ago but was never really happy with the results.
I looked on Rockauto and Amazon and noticed that Hitachi sells just the sensor for $109 (for the 2k2) and bought it. For the last three weeks, my car has never run better. It may be a good alternative for those who don't want to modify the 2k1 MAFs. Hitachi is the OEM supplier for Nissan coils so I figured they would make a decent MAF and I like the outcome.
Here is the 2k2 MAF I bought from amazon.
Amazon.com: Hitachi MAF0095 Mass Air Flow Sensor: Automotive Amazon.com: Hitachi MAF0095 Mass Air Flow Sensor: Automotive
Old Sep 28, 2015 | 08:46 AM
DennisMik's Avatar
Great info. Thanks for sharing.
Old Sep 29, 2015 | 06:08 AM
~V~max's Avatar
did you have power loss when warm or all the time? mine has lots of power loss when it gets warm, when cold its a while different car
Old Sep 29, 2015 | 11:20 AM
TallTom's Avatar
I felt power loss most of the time but worsened when warm.
Old Sep 30, 2015 | 01:26 AM
jjubert's Avatar
I bought one today, thanks for the heads up
Old Sep 30, 2015 | 08:06 AM
TallTom's Avatar
No problem. Report back after the install.
Old Sep 30, 2015 | 08:44 AM
NmexMAX's Avatar
dot dot dot ...
What did you pay? Saw the price go to $115.
Old Oct 1, 2015 | 06:08 AM
TallTom's Avatar
I paid $109 on Amazon.
Looks like it went back to $109. I just checked.
Old Oct 1, 2015 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
I'd better get on that.
Old Oct 1, 2015 | 05:49 PM
Nyshadow's Avatar
I can but that same part for my 2003 right?
Old Oct 2, 2015 | 08:09 AM
NmexMAX's Avatar
dot dot dot ...
Old Oct 2, 2015 | 03:48 PM
WTF?'s Avatar
http://www.ebay.com/itm/MASS-AIR-FLOW-SENSOR-METER-for-MAXIMA-G35-I35-22680-AM600-NEW-/181403473961?fits=Year%3A2002%7CModel%3AMaxima&hash=item2a3c7d5829&vxp=mtr
On my car now....runs perfect.
Old Oct 3, 2015 | 11:03 AM
The_Fixer's Avatar
Just buy the oem 5th gen for $77 and swap over the thermosistor
Old Oct 3, 2015 | 03:17 PM
a33_ridah's Avatar
Looks like the price keeps changing within a small range...good buy nevertheless.
Old Oct 4, 2015 | 07:24 AM
kvk2003max's Avatar
Amazon says it does not fit a 2003 Maxima. Is anyone using this on a 03 max?
Old Oct 4, 2015 | 05:20 PM
ajahearn's Avatar
02 & 03 engines use the same MAF.
Old Oct 4, 2015 | 05:21 PM
ajahearn's Avatar
Just to be clear, the amazon part doesn't look the same so I have no idea if you have to take anything off or modify it in any way.
Old Oct 4, 2015 | 07:14 PM
kvk2003max's Avatar
Hitachi catalog shows a different part number for 2002 and 2003 maximas
http://www.hitachi-automotive.us/htm...talog_2013.pdf
Page 216.
Old Oct 5, 2015 | 12:37 AM
jjubert's Avatar
I installed this MAF on Saturday to see if I could improve my gas mileage issue, but that info will be granted in due time I guess.... but on another note, I can tell my idle has gotten smoother, and acceleration has improved also so I am pleased with the purchase
Old Jan 21, 2016 | 12:14 PM
a33_ridah's Avatar
So i had purchased the $22 Maf posted in this thread as well....
that may be my issue i think still. Still experiencing rough idle/power surge/lack of power issues. Guess will be buying the hitachi one next.
Old Mar 5, 2016 | 02:22 PM
b0nes's Avatar
Still no luck at all I'm running out of ideas to check what else could b doing this problem to the car 3 weeks without a car sucks code 1122
Old Mar 6, 2016 | 12:14 AM
DennisMik's Avatar
Code P1122 is the Electric Throttle Control Actuator assembly. It consists of the throttle control motor, throttle position sensor. The throttle control motor is operated by the ECM and it opens and closes the throttle valve.
The opening angle of the throttle valve is detected by the throttle position sensor and it provides the feedback to the ECM to control the throttle control motor to make the throttle valve opening angle properly in response to driving condition.
You either have a bad Electric Throttle Control Actuator or the wires going to it are damaged.
Old Mar 6, 2016 | 09:30 AM
b0nes's Avatar
I already bought a new throttle body and did the relearn so many times it doesn't pick it up ..the wiring i already check it out they look good to ..could it be my battery? Or a relay?
Old Mar 6, 2016 | 02:44 PM
DennisMik's Avatar
Check 15 amp fuse # 63 that is under the hood by the battery. It is towards the front of the car and the cover has the label THROT MTR on it.
There is a relay in the circuit. It is in front of the battery, the row next to the battery, 3rd one from the left. Relays don't go bad that often, but it is a possibility.
Old Mar 19, 2016 | 06:01 AM
Rochester's Avatar
I just found the original MAF Sensor from my old 2003 Maxima SE 6MT, sitting in a box of parts from way back when. It has approximately 50K miles on it, from 2003 through 2010. There are zero problems with the unit... at the time my thinking was to experiment with the 2001 MAF + Honeywell Thermistor, and have the original as a back-up, since the MAF is a known point of failure on the 2002-2003 Maxima. (That approach works just fine, BTW. Although my soldering skills suck *****.)
New, the price is stupidly high. We all know that, and are familiar with the sticker shock when you need one. Now that there are aftermarket MAFS (because there didn't used to be), it seems to go for $110+. After discovering that I still had this part, I thought about creating a FS thread, but then found this active thread when researching what to do with it.
Most of you here probably don't remember me, but NmexMAX can vouch for Rochester, right Manny?
Old Mar 19, 2016 | 07:45 PM
03Alt3.5Biz's Avatar
Rochester, I can vouch for you
Old Mar 20, 2016 | 12:49 AM
Child_uv_KoRn's Avatar
Bad *** Newb
We remember you, sweet thang
Old Mar 20, 2016 | 05:50 AM
Rochester's Avatar
You guys are still here? Wow.
If someone wants this MAF for $50 shipped, I'd be happy to box it up. Just PM me.
Old Mar 20, 2016 | 06:49 AM
Bad *** Newb
Old Mar 20, 2016 | 12:41 PM
WTF?'s Avatar
I'm still running the 22 dollar one. Runs fine for me.
Old Mar 20, 2016 | 12:58 PM
Rochester's Avatar
Is the OEM MAF still $400?
Solving your problem at less than 5% of Dealer Cost... that's awesome for as long as it lasts. Wish that were an option years ago.
Old Mar 20, 2016 | 01:12 PM
WTF?'s Avatar
It seems to be working fine, I've actually purchased two, I tried to pull the thermistor out of one to spray my water/meth across, but in the process hacked it up. I bought aother, and it works fine also.
Old Mar 22, 2016 | 06:51 AM
cdoublejj's Avatar
So this mod and or aftermarket MAF improve performance? Is this true with the 2001 3L too?
Old Mar 22, 2016 | 08:49 AM
NmexMAX's Avatar
dot dot dot ...
No, no performance gain.
Larger MAF housing using the same OEM MAF is a good idea, but not that straightforward.
And yes Rochester, there are a few MAF's now even the 02+ that are relatively inexpensive not 400$, and of course there's the 00/01 option wnad swapping the thermistor, and of course the community has matured more so as of late that now even the thermistor is available for separate purchase.
Old Mar 22, 2016 | 08:53 AM
Rochester's Avatar
That's fascinating. Welp, I created a FS thread anyway, and am selling it $40 shipped, in case someone wants an OEM replacement or backup.
Hope all is well, Manny.
Old Mar 22, 2016 | 09:17 AM
NmexMAX's Avatar
dot dot dot ...
Someone should jump on this. Great price.
Old Mar 25, 2016 | 07:13 AM
cdoublejj's Avatar
I have an 01 3L, do i already have a decent MAF?
Old Mar 25, 2016 | 08:41 AM
Rochester's Avatar
It's just a sensor, neither good nor bad.
Old Mar 25, 2016 | 11:52 AM
brandon9686's Avatar
Here is the 2k2 MAF I bought from amazon. Amazon.com: Hitachi MAF0095 Mass Air Flow Sensor: Automotive
I have a 2002 maxima gle I looked at rockauto.com and the hitachi for rockauto number is different than the one you mention on amazon will it still work the same. Rockauto.com hitachi0099 Amazon.com hitachi0095
Old Apr 29, 2016 | 07:08 PM
96SEmaxB's Avatar
Maf 50$ shipped still FS?
