Wheel noise from back left
I was drivin in the snow the other day and i have crappy tires and i was slidin around a corner and my back left wheel smacked a curb and ever since there has been a grinding/whining noise coming from my back left wheel. I checked and theres nothing for the tire to rub against(at least when its sitting) but when i hit 35 mph and up it sounds like i have a muddin tire back there. could this be a berring or is the tire rubbing something? It is also has a bit of a loose rear end. any help would be much appreciated
Originally posted by maximase86
Couple possiblilities. You knock the wheel out of balance, you screwed up the wheel hub, or your bearings are bad. I take it in and have it looked at when you get the chance.
S
S
I took it into the shop and my alingment was off a little so they fixed that and they took a big chunk of snow out of my wheel well and the noise stopped for about a day. The mechanic said that the camber was off an 8th of a degree on that wheel also. But the noise is back now im gonna replace the bearings and see if that stops it.
trasmadean
Feb 1, 2017 08:20 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
