Turbo piping
Old Jan 23, 2003 | 03:50 AM
2002Maxxxima's Avatar
Turbo piping
When you go turbo on a Max, do you use the exhaust from both sides of the engine or just one? If it's just one side, does it affect how that half of the engine performs being that there is more vaccuum on that side? Or does the turbo connect at some point after the two exhaust manifolds come together?
Does anyone have any pics from above and underneath of a FWD V6 turbo car? I guess I don't really understand the piping.
Thanks!
Old Jan 23, 2003 | 04:53 AM
Stephen Max's Avatar
Re: Turbo piping
Thanks!
If it is done right (and it is not a twin turbo), the exhaust piping from both banks of cylinders is manifolded together before the turbine. This is done as a matter of course in the y-pipe of a single exhaust system, but routing of the pipes in a turbo setup is more circuitous because of the need to locate the turbine in a place where you can route the intake pipe as well.
Old Jan 23, 2003 | 05:56 AM
Re: Re: Turbo piping
Thanks for the info. That is pretty much how I imagined it. Funny though, there just isn't a lot of room in engine bays, that's what is so intriguing; all that piping.
So would it use a special y-pipe then? A y-pipe that went to the turbine instead of the exhaust, then from the turbine back through to the exhaust where the y-pipe left off?
Old Jan 23, 2003 | 06:07 AM
Re: Re: Re: Turbo piping
You got it.
Old Jan 23, 2003 | 01:07 PM
hlh0501's Avatar
you just described my turbo kit and amazingly enough, there is enough room for it all, althought here is a LOT of piping in there especially when you add the intercooler piping to it, and the charged air around and back to the throttle body, add the intake in there , and you've taken up some serious room... all fits and works beautifully though
Old Jan 23, 2003 | 04:33 PM
Re: Re: Re: Re: Turbo piping
Yes, I think I've watched vids of your car on vqpower.com
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
09maxshawn11
Sep 30, 2015 10:28 AM
