What's the optimal AFR?
Re: What's the optimal AFR?
"Perfect" air to fuel aka stoichometric mixture if N/A is 14.7:1, if boosted is 12.5:1. Won't necessarily give the most power though of course.
Originally posted by Stephen Max
Can somebody tell me what is the optimal AFR for a NA engine and for a supercharged engine running 9psi of boost?
Thanks!
Thanks!
Re: Re: What's the optimal AFR?
The reason I ask is thay when my car was dynoed (NA) the dyno operator said I was running lean, even though the AFR was at about 12.4-13 (50 psi fuel pressure at WOT because of the Walbro fuel pump, no SARD yet). That doesn't seem lean for NA operation does it?
dyno with AFR
Re: Re: Re: What's the optimal AFR?
dyno with AFR
dyno with AFR
I am NA, and my AFR was around 14 for the most of my run:
http://forums.maxima.org/showthread.php?threadid=186878
http://www.glue.umd.edu/~nauman/images/dyno.jpg
http://www.glue.umd.edu/~nauman/images/afr.jpg
Originally posted by 20th maxstyle
Perfect Stoich is 14.72 parts of air to 1 part fuel.
Too much inaccurate information!!!!! Stoichometric mixture will not yield the most power at WOT. 14.7 will yield optimal fuel economy. Most car engine will yield the most power between 13.1:1 or even less during acceleration and top speed.
Just to show a real world example. Take a look at Nigal's recent dyno. Notice he made extra 29hp because his A/F ratio was a tad richer. Take a look at the red compare to the blue in the A/F ratio graph. I would tune my car to 12.5 A/F ratio.
http://home.attbi.com/~nigelc33/429HPdyno.jpg
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
speedemn
26
Jun 10, 2002 09:25 AM
max'n out
Jan 4, 2002 09:12 PM
