Dyno (finally!)
Old Jan 25, 2003 | 09:31 PM
turbo97SE's Avatar
Dyno (finally!)
Check this out:
http://forums.maxima.org/showthread....9&goto=newpost
Old Jan 26, 2003 | 09:47 AM
Engloid's Avatar
Re: Dyno (finally!)
Originally posted by turbo97SE
Check this out:
Nice!!
My question...what is causing the dip in the air fuel curve? Maybe you could get a larger plateau on the hp and torque curves by figuring that out.
Old Jan 26, 2003 | 11:47 AM
mtrai760's Avatar
'Trynna' is not a word
YGM & PM
Old Jan 26, 2003 | 12:17 PM
metallic97gxe's Avatar
Master Will
the HP king.............
Old Jan 26, 2003 | 04:59 PM
sx7r's Avatar
aw shiet, beat me by 10ftlb. lol, nice numbers
Old Jan 26, 2003 | 05:52 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
thomas, 10 ft/lb referring to the dpi setup before?.. or now?
Old Jan 27, 2003 | 11:40 AM
Deac's Avatar
Re: Dyno (finally!)
Check this out:
excellent Nig... Those numbers are unreal! Nice job.
Deac
Old Feb 5, 2003 | 12:59 PM
1MAX2NV's Avatar
Re: Re: Dyno (finally!)
The dip actually cost him to make more HP. The dip in the A/F ratio means he's running richer.
Originally posted by Engloid
Nice!!
Old Feb 5, 2003 | 01:26 PM
Engloid's Avatar
Re: Re: Re: Dyno (finally!)
I can't seem to access the chart now, but I believe that if you look closely you will see that there was a dip in the A/F curve, just below a point in the torque/hp curves where there is a dip or decrease as well.
If you were correct, then my question would have been "why not make it lean like that along the whole curve?"
I believe I am right, but you may still show me to be wrong.
maxima297
Sep 30, 2015 03:32 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
