shifting
Re: shifting
Originally posted by bagged89s10
i have an 87 maxima. Does engine temp have anything to do how it shifts. It's an automatic. It sems that if the car is not warmed up it will not shift into the last gear.
S
Yeah my car pulls that crap too, If i don't think about it and just let it warm up for a couple minutes and i try to drive at 55 and up it wont lock into Over drive. Its really annoying because it'l hold at about 3500 until it gets halfway up to temp. Then drop to 2.
Oh well
Oh well
Re: Re: shifting
thanks for the info. Yes it takes long to warm up and i am in about 20 dergee temps. I will change the thermostat asap. Thanks again
If it really bugs you, there is a fuse in the fuse panel you can pull, and then the car will shift into overdrive regardless of how cold it is. I found this out by accident when one of my cooling fans shorted out and blew the fuse. I noticed I was getting overdrive right away. It's a 15AMP that says 'transmission/cooling fan motor'. You lose your cooling fans, too, but if it's -15celsius (it is where I am) and you're highway driving, you probably won't need the fans. Be warned that I have no idea if this will damage your tranny. I personally don't do it.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
