prep for turbo
Old Feb 13, 2003 | 02:10 PM
Redmax's Avatar
Redlinemax Owner
prep for turbo
Ok, I have decided that i will be getting a turbo!!!! But as an automagic I want to protect my investment as much as possible.I will be "bulletproofing" my tranny by a shop in md For about 1900. This place will warranty my tranny for 3 years ewven after boost is put on. Is there any other precautions that i should take before putting the boost on this car?? any parts known to break or anything?
Old Feb 13, 2003 | 02:16 PM
PCGuRu2K's Avatar
Re: prep for turbo
How many miles do you have on your car? For auto's you can't really run that much boost. Maybe no more then 8psi. Anymore then that and you can blow your tranny even with bulletproof tranny. I've seen a guy have to redo his bulletproof tranny twice when he had turbo on an auto. You're motor probably couldn't handle it either.
Old Feb 13, 2003 | 02:27 PM
Redmax's Avatar
Redlinemax Owner
Re: Re: prep for turbo
60,000
Old Feb 13, 2003 | 02:36 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Motor can handle it fine.
Auto tranny can handle more than 8 lbs... and you don't have THAT many miles on her.... Especially if you get a bulletproof tranny that's warrenteed like that... Go for it!!
Old Feb 13, 2003 | 05:56 PM
BigDogJonx's Avatar
PCGuru2k, believe me, the place he is getting it done is 10x better than Level10. You know Max N' Out right? He got his done there. Posi traction, strengthened case, gear ratios changed. The works.
Corey, I guess you finally boosting. Who gonna do it?
Dixit
Old Feb 14, 2003 | 06:23 AM
hlh0501's Avatar
For auto's you can't really run that much boost. Maybe no more then 8psi. Anymore then that and you can blow your tranny even with bulletproof tranny. You're motor probably couldn't handle it either.
If you have it done properly, and is warrantied, I don't see why you can't run 10-12psi, which is probably about as high as you want to go on stock internals... the motor can handle more than 8psi, but be very careful going above 10!
May I ask who is doing your tranny work, and what exactly they are doing for 1900? Thanks - good luck, let me know if i can help with anything.
Old Feb 14, 2003 | 08:34 AM
BigDogJonx's Avatar
Re: Re: Re: prep for turbo
NRH Transmissions out in Jessup MD will be doing the work. As far as exacts on what he is doing, going to have to ask Corey.
Old Feb 18, 2003 | 10:50 AM
booboo1312's Avatar
Do they work on manuals or is it necessary? I'm lookin to upgrade my engine later and transmission after I put in the turbo. Hopefully my car will be turboed by summer time.
Old Feb 18, 2003 | 02:51 PM
BigDogJonx's Avatar
They will do whatever work you need done on a tranny period.
Old Feb 19, 2003 | 02:37 PM
1MAX2NV's Avatar
Re: Re: Re: Re: prep for turbo
Last time I asked about a bulletproof tranny, they quoted me around $3000. That's with everything that Jayson got.
Old Feb 19, 2003 | 02:54 PM
BigDogJonx's Avatar
Re: Re: Re: Re: Re: prep for turbo
And thats correct. Jayson has Posi traction done. If you dont want that, he knocks off about 1000.
Dixit
Old Feb 20, 2003 | 05:56 AM
Dreizehn's Avatar
Re: Re: Re: Re: Re: Re: prep for turbo
Dixit
What is Jayson running with the tranny (boost or N2O)? Has he had any problems?
Old Feb 20, 2003 | 06:52 AM
MAXIN's Avatar
Um, is posi-traction similar to LSD? Explain please.
Old Feb 22, 2003 | 08:52 AM
1MAX2NV's Avatar
posi-traction is LSD. The ole school tuner calls it posi.
Old Feb 22, 2003 | 10:08 AM
MAXIN's Avatar
thanx
Old Feb 23, 2003 | 01:25 AM
turbo97SE's Avatar
Re: prep for turbo
You must really like automatics cos you can do a 5 speed swap and a Quaife diff for about that much money ... maybe a little more... or just the LSD tranny for much less.
Old Mar 20, 2003 | 10:30 PM
Redmax's Avatar
Redlinemax Owner
Hal the guy who is doing the tranny work says there is too much to list, he changes the gears belts everything in the tranny. Right now i cn't afford the 1900 so i'm getting my vb done by him tomorrow. He doesnt just redrill your current vb and chage the springs. He actually rebuilds the whole valve body himself in his shop.
Old Mar 21, 2003 | 11:02 AM
breaux124's Avatar
Remember the movie "My Cousin Vinny"?
She explains Posi-traction, which is how I knew it was the same as LSD. See, we can learn something useful from a movie
Old Mar 21, 2003 | 04:33 PM
MAXIN's Avatar
your right.....
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
