Auto VS Manual
Old Feb 15, 2003 | 10:27 AM
eclypsecl's Avatar
Auto VS Manual
I've never driven a manual transmission car..is there an acceleration difference etc..so if you put a stock stick, and stock auto side by side the one with manual would be further ahead, or is it just a matter of prefrence?
Old Feb 15, 2003 | 10:34 AM
TheMax95's Avatar
Re: Auto VS Manual
Yes the manual will win. by a lot. Almost a second faster at the 1/4 mile if driven well. Both have 190hp and 205 lb ft at the crankshaft but the 5speed gets more power to the wheels becuase their is less drivetrain loss. Plus you control the car's shifts.
Old Feb 15, 2003 | 10:35 AM
JetBlackMax's Avatar
Re: Auto VS Manual
The Manual is faster then the auto because of the shift points. Manually shifting can make a longer shift then the Auto shift does. They dont have that torque converter. So when our auto shifts at wide open trottle at about 6000 RPM, They can shift it at redline at 6500 RPM for a longer shift, which in case, makes them just a tad bit quikcker. Now stock vs stock, with a Person who can DRIVE the stick, Will beat you, but not by much. You wouldnt get BLOW OUT in the race, but you wouldnt beat them because of the manual. You can also Manually drive the auto, but in most case, it doesnt help to much, just a little bit, because even if you shift at redline, it still takes that one second, to actually SHIFT into gear. Manually it shifts as soon as they shift it.
Nick
Old Feb 15, 2003 | 11:12 AM
arlan's Avatar
manual 4 sure
Old Feb 15, 2003 | 11:28 AM
costcowholesale's Avatar
Re: Re: Auto VS Manual
Nick
I shifted mine @ 6650 every gear & still got smoked by 5speed maximas at the track its not the shifts that kill autos... and my tranny doesn't take one second to shift...
auto's gear ratio sucks, if they have the same ratio as 5speed it'll be a lot closer on highway/in third. once auto hit third we're screw the gear ratio gap is too big
Old Feb 15, 2003 | 11:51 AM
99maximagxe's Avatar
Re: Re: Re: Auto VS Manual
I believe thats true too because this generations automatics are closing in closer to 5 speeds. autos are not that far behind.
Old Feb 15, 2003 | 02:26 PM
Dev's Avatar
Dev
Nick
umm...no
its not the shiftpoints that makes the difference.
i can shift at 6000 in each gear and still beat an auto shifting at 6500.
as TheMax95 said, its the difference in drivetrain loss between the torque converter of an auto to the flywheel of a stick.
manual puts more power to the WHEELS, which is what counts, not the CRANK.
it would take an absolutely awful driver with a manual to lose to an auto.
Old Feb 15, 2003 | 02:54 PM
Jime's Avatar
Automatics just plain suck.
Old Feb 15, 2003 | 05:27 PM
dwapenyi's Avatar
Actually, the auto gear ratios don't really suck, it's just that it doesn't have enough of them, like the 5 speed.
DW
. . . auto's gear ratio sucks, if they have the same ratio as 5speed it'll be a lot closer on highway/in third. once auto hit third we're screw the gear ratio gap is too big
Old Feb 15, 2003 | 08:40 PM
TheMax95's Avatar
Originally posted by Dev
umm...no
Well said.
Old Feb 15, 2003 | 11:12 PM
Re: Re: Re: Re: Auto VS Manual
DW
third gear sucks, its too tall.
punch it from a 70mph roll, you'll see
Old Feb 16, 2003 | 12:21 AM
Dev's Avatar
Dev
Originally posted by TheMax95
Well said.
thank you
Old Feb 16, 2003 | 01:12 AM
lefty
Not really, I can eat an ice cream and talk on the phone while still driving my Max in stop and go traffic.
Old Feb 16, 2003 | 02:04 AM
Jime's Avatar
What I really meant was that its nice to be able to go to the track and run low 13's (hopefully 12's this year) by just changing the tires and hitting a button.
Then, bring it back home and Monday morning the wife takes it grocery shopping and its a 15 sec car again.
Old Feb 16, 2003 | 10:00 AM
Tuna's Avatar
so the torque converter is where the loss occurs, hmm..?? do they have like performance torque converters for the 4th gen, and if so, how much hp gains at the wheel and crank can be expected from said converters..??
Old Feb 16, 2003 | 10:06 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Re: Re: Re: Re: Auto VS Manual
punch it at 90+ and it's a different story.. but what you said first was best
Old Feb 16, 2003 | 10:13 AM
Re: Re: Re: Re: Re: Re: Auto VS Manual
how do u get to 90 without hitting the 70 spot
yeah about 85~ it starts picking up & pulls hard again, but I cruise at 70 on the highway everyday, whenever I floor it doesn't do much till 80+ 5speed will be around high 4000s rpm in third and pulling hard
Sprint's Avatar
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
