car is making a tick sound
Old Feb 16, 2003 | 02:26 PM
acidspit86's Avatar
car started making a funny sound a little while ago. it only happens when im accelerating. Its sounds like chick chick chick,and im sure its coming from the engine bay, not the exhaust. any ideas? thanks in advance
Old Feb 16, 2003 | 02:27 PM
acidspit86's Avatar
btw its a 1991 maxima se 5spd. 98,000 miles
Old Feb 16, 2003 | 02:31 PM
D-sta's Avatar
sounds like exhaust studs very common on the VG maxima. Do a search and you will find tons of info on exhaust studs.
Old Feb 16, 2003 | 02:37 PM
acidspit86's Avatar
so i can just replace the bolts?
Old Feb 16, 2003 | 02:39 PM
D-sta's Avatar
yes you can replace them, just as long as you pay and it's not an easy job and most likely it's the exhaust studs located in the back by the fire wall which makes it much harder. I recommend taking this to a good mechanic and make sure you get good quality studs so ths never happens. This job will run you a lot and expect to pay.
Old Feb 16, 2003 | 02:40 PM
Michael's Avatar
Back in a 3rd Gen.
you will have to get them drilled out. Thats not as easy as it sounds unless the heads are off of the car.
Old Feb 16, 2003 | 03:11 PM
acidspit86's Avatar
what is a good site to order these bolts from? how much do you think it will cost to get those replaced?
Old Feb 16, 2003 | 04:42 PM
D-sta's Avatar
I think if you call www.courtesyparts.com they stock the new and imporved studs but I might be wrong, if you conduct a search you will find a definte place where to get them.
Old Feb 16, 2003 | 05:05 PM
Badness's Avatar
could be your water pump...........
Old Feb 16, 2003 | 05:06 PM
D-sta's Avatar
why do you say that?
Old Feb 16, 2003 | 06:03 PM
acidspit86's Avatar
what would happen if i were to just ignore this problem? performance loss? just that clicking sound? or would something serious be caused?
Old Feb 16, 2003 | 06:29 PM
D-sta's Avatar
well yes you would loose power and eventually the noise get worser and worser.
Old Feb 16, 2003 | 06:35 PM
rcy's Avatar
rcy
Re: car is making a tick sound
Only when you're accelerating? It's not spark knock is it? Or pinging?
Old Feb 16, 2003 | 06:41 PM
acidspit86's Avatar
yes, or at least i can only hear it when im accelerating. dont know what spark knock is and its not pinging. i use 93 octane, just like the manual says...
Old Feb 17, 2003 | 01:53 PM
JD's Avatar
JD
Mine goes away after it warms up. Mechanics I spoke with(private garages and Nissan) said it only had to be fixed if it bothered me that much, otherwise no ill effects. It's passed the emissions with no problems in the 6+ years I've had it...
Old Feb 17, 2003 | 05:35 PM
acidspit86's Avatar
mine doesnt go away, sounds like its gotten a little louder
Old Feb 17, 2003 | 09:08 PM
rustangkilla
Expect to pay around $500 for an exhaust stud job. The parts were cheap, but labor just r@ped me. They had to take a ton of parts off and and do some heavy duty extracting. Not to mention it is a dangerous job...drill to far in and your through a cylinder wall. Just something to think about if you decide to do it on your own.
Old Feb 17, 2003 | 10:33 PM
D-sta's Avatar
exactly if you're going to get it done, get it done by a professional certified technician.
Old Feb 18, 2003 | 04:27 AM
acidspit86's Avatar
geez, seems like since ive got this car all ive done is fix it. and this will be the most expensive. hehe, and i thought i was finally done with it...
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
AT978
Aug 15, 2015 06:39 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
