Broken back dash???
Old Feb 22, 2003 | 07:15 PM
Luv4DSC's Avatar
Broken back dash???
Anybody broke their back dash? Mine has 3 cracks in it, and it squeaks like crazy all the time, very bothersome. Any ideas? I was thinking of just putting dynamate over them on both sides to help stablize the cracks but don't know if that will work or if the dynamte will just tear when the metal flexes. thanks
Old Feb 22, 2003 | 09:38 PM
Matt93SE's Avatar
STFU n00b!
uhhhh, exactly which part broke, and HOW did it break?
Old Feb 23, 2003 | 01:27 AM
Dark Lord Bunny's Avatar
There's a bunch of Maxs being parted out, why not just replace???
Old Feb 23, 2003 | 10:31 AM
Luv4DSC's Avatar
Well the back dash is welded into the car so replacment would be a *****, and it broke there the speakers are placed, there is about a 3x6in slot in the dash 3 inches in front of the speakers,this is were the two cracks are and the thifd is in between the two 3x6 slots. The dash broke I'm sure from the stress of the subs just shakin the crap outta it, cuz when it hits hard it shakes your eyes so that is the culprate.
Old Feb 23, 2003 | 02:19 PM
probmxstyle's Avatar
I would say mix up a nice batch of JB weld and fill the cracks and not drive the car till it sets.
Old Feb 23, 2003 | 05:20 PM
Luv4DSC's Avatar
Yah I was thinkin bout jb weld and then dynamate over it for extra support so I guess thats what I'll do and see if that fixes the problem. Thanks
Old Feb 23, 2003 | 06:32 PM
No problem, let me know how it turns out, i actually have dynamat on mine. I put it on the bottom of it. It also keeps air from my subs to go thru the holes and making my rear dash cover vibrate uba nd down.
Old Feb 23, 2003 | 07:22 PM
Michael's Avatar
Back in a 3rd Gen.
Why dont you actually have it welded up. That is the strongest thing to do instead of jb weld. Dont get me wrong I like jb weld and it is a good strong product but if you can get someone to weld it then it would be a lot stronger.
Old Feb 23, 2003 | 09:57 PM
Matt93SE's Avatar
STFU n00b!
use some small pieces of plate steel and place over the cracks a few inches on either side.
Squirt RTV silicone all over the mating surfaces, then screw together with some sort of small bolts/screws. the other option is to weld it and repaint. veyr messy either way, but the steel/silicone method you can do yourself in the driveway.
Old Feb 23, 2003 | 10:08 PM
Luv4DSC's Avatar
If I was gonna go that route I was looking to maybe rivet another small piece of sheet metal over the cracks but not looking forward to riveting...I think I'll try the jb weld first, then if that dosn't hold I'll just actually weld the damn thing.
Old Feb 23, 2003 | 10:14 PM
Matt93SE's Avatar
STFU n00b!
I'll save the time for you... JB weld WILL NOT work.
not strong enough.
Old Feb 24, 2003 | 08:36 AM
Luv4DSC's Avatar
okay thanks..I'll just weld it then me no like welding sheet metal. That freakin rattle is driving me insane all the time squueeekk,skkeeq
Old Feb 24, 2003 | 09:07 AM
not strong enough.
Jb weld will work, just put it on the top and bottom of the crack. And scuff up the surface so it sticks good. You can weld it, but have someone with good experience, cause welding a long crack on that thin metal with those up and down bends can be hard.
Old Feb 24, 2003 | 09:47 AM
Matt93SE's Avatar
STFU n00b!
Any goon in an exhaust shop can weld that. If they can weld on round pipe, flat sheet metal will be easy.
and JB weld will not work. if there is enough stress there that it's tearing apart sheet metal, JB weld will not have the tensile strength to hold together either.
Old Feb 24, 2003 | 03:23 PM
Yeah thats true, If you dont feel like paying some one to weld it, at least JB will keep it from moving up and down and squeaking. If you go that route drill a small hole at each side of the crack to prevent it from growing.
Old Feb 24, 2003 | 08:26 PM
Luv4DSC's Avatar
Well the cracks are already maxed out unless more appear so stoppin the spread isn't possible..I didn't notice it until it was too late to stop it and now the whole damn dash just shakes like a crack fiend.
JRod28
Dec 29, 2023 09:56 PM
tnewbs
Aug 28, 2015 10:15 AM
MikesChevelle
Aug 6, 2015 11:36 AM
