bucket seats to replace rear bench seating in the maxima
i would like to get rid of the bench seat in the back of my max and put 2 more bucket/front seats in there and then make a center console to run from between the two back seats and connect to the already existing center console.i am sure this would take some work. but i am pretty sure this could be done, well i know it could be done. i think the center console would be the tricky part, as far as making it look good anyways.as far as putting the seats back there i dont think that would be to hard. only i would need a shorter seating bracket so that the seat wouldn't be 3-4 inches above the rear bench platform.has any one seen this done, would this be worth persuing. any ideas would be great.
Originally posted by Romeo
good luck. i hope you figure out how to do it. i believe you'd be the first. make sure to take plenty of pics along the way
i've been thinking of doing that for a while now, just dont know how it could be done, having two bucket seats in the back would be great, but sadly i dont have the resources or the time to attempt such a feat right now, keep us in the loop. i wana see how it turns out.
I think it could be done.
I would suggest using the existing bench seat because it already fits. Cut it into two halves. Remove the excess from the middle of each half where the new center console extension will go. It might be a good idea to get a professional apolstry shop to handle this so that it will look good when finished.
Then you may or may not need to fabricate another latching mechanism similar to the ones already on your seat to help hold it down in the middle.
After that is done get a scraped center console from a local salvage yard, and use it for your center console extension. I'm not to sure how you would fasten it to your exsisting console but I'm sure that it could be done. Just get creative with it.
The beauty about this is you don't have to modify the seat back.
If you do this send me some pics. LOL
Originally posted by Triocet
no no, not cutting the rear bench apart, removing it completely and adding two nice racing seats.
i kinda got lost in what you were saying there, in any case, see what you can do, i'll try to look around to see if there are any sports cars with bucket front seat that could fit in the back of the maxima.
The biggest problem you will find is getting in buckets that will actually leave leg room back there. Just compare your front seats to your rears and you'll see what I mean.
As for doing the console, that's actually pretty easy. Just make a mold/frame, easiest would probably some kind of foam that you could shave down to shape. Then layer fibreglass over. 3 layers will be plenty for this application. Then shape with cutting/sanding. Then use a putty/filler to make smooth, then prime and paint. It'll probably take one weekend to do this part.
Originally posted by maxspeed96CT
Its possible because people in hondas do it allthe time, But WHY??
It is a waste of time and lots of money.
you will have to cut into the frame if you use seats because of the height ,your best bet is to get molded foam to shape this up because there are already two nice dips in the metal.
i dont want people in the rear seat to be flying around when power slide into a corner....
If you want to push the limits of your car, keep it to the track. Especially hard cornering.
You do know what a powerslide is, right
Dave
Re: bucket seats to replace rear bench seating in the maxima
seat. Voila! Instant bucket seats.
after i read this thread to my girl and asked her what she thought.. she said that i should build a bed back there cause that's the only thing i have left to do with my car is sleep in it... i says to her.. hmmm.. good idea honey!
what about leaving the back part of the bench there, removing the lower part(the part you sit on) and remove the bottom portion of the buckets. and just install that portion with the back part of the original bench. you would have half bench half buckets.there is almost no chance this would work, but it is an idea.
Originally posted by MacGyver265
Did everyone forget about the pass-through? Isn't the seat back the barrier between the trunk and the rear seat section? If you take this out, won't you have a big gaping hole to the trunk?
to name one find some carpet to match the existing, take out the back dash and recarpet it, and the back panel while the seats are out install seats this would take care of the hole. or you could leave the hole there
i think this would be a neat idea. i imagine the car would feel alot sportier to the passengers. if it was my way i would just put maxima buckets in the back instead of aftermarket racing ones. some problems that i thought of for this install are the reclining features for the seats. obviously you wouldnt be able to recline so at what angle would the seats be at(90 degree right angle?) or could it be reclined slightly for some comfort. i drew up a lil diagram of how the back would look and it looked sick as hell. I created a nice lil console between the 2 back seats and it conects to the front console. between the seats was a compartment like the front one between the front seats, i had cup holders and everything. This sounds like a modd i seriously might want to do while i convert my tan cloth interior to black leather. It also gives me an excuse not to cram my car with people. (sory i can only fit 4 people
Maxima 2+2... sounds cool
)Maxima 2+2... sounds cool
alright well i took some measurements the height of the front seat from the mounting bracket to the highest point on the bottom part of the seat is around 10" tall. and the height of the rear lower part of the seat from the tallest part of the car the seat sits on, basically the rear seat measures about 3-5". so if you did this with the existing bracket(modified of course) if you were siting in the back you would be sitting about 7" higher than with the bench. and that sucks...but as far as width is concerned the seats would definatly fit with 2"-3" to spare.
I have a feeling you're going to find out how much this costs, then realize it's not feasible.
Originally posted by Sin
7"!!! You gonna put 4' tall people in there?
obviously this is not the route to take, is what i was trying to say. sorry you did not pick that up. id definatly have to do something about the bracket to bring the seat height down 4-5" at least.
The only way I see this happening is as follows. Get aftermarket REAL sport seats. The ones with nearly no padding, basically shaped plastic/carbon fibre, THIN padding, and little else. Then you'll have to cover the rear, carpet it so it doesn't look bad. Then mount the seats using as little mounting hardware as possible. And making a custom fibreglass enclosure.
Just getting the seats will probably be about $1000 US. The rest will only cost about $150 in materials. However, it'll probably take about a solid week of work.
Originally posted by pezking4
basically you want the 04 maxima treatment?
If you made it look stock it could cost a lot. How good are you at finding materials , etc.
that you were able to do with the bench seat..but I guess where theres a will theres a way...goodluck
