oil return line
Re: oil return line
Originally posted by MaXtUneD
Couldnt I just use the oil return line from the turbo and connect it to the existing drain plug??Or do i have to drill a hole on the side and why?
Re: oil return line
I forgot why though...can someone explain to me? thx
Re: oil return line
So what would happen if my oil is being drained back to the pan and a hole was drilled on the pan right in the middle of the pan from the side. It is a large line, like about 3/4" braided line.
Dixit
Dixit
Dixit
Dixit
12AN is 3/4" (12/16) I.D...
I really don't see how it makes any difference to the turbine whether the oil return line enters the oil pan above or below the oil level. Making the entrance below the static oil level won't stop oil from flowing into the oil pan from the turbine. The only things that matter are that the turbine is above the oil level, and that you use a big enough return line to handle the flow rate.
Originally posted by Chunger
Have you been 20+ feet underwater? Liquids have mass... mass exerts pressure -> restriction.... memories of good old Physics back in highschool.... LOL
The very top of the oil pan is near or above the top of the oil level when the car is running from what i have been told, is this correct? I return my oil to the very top of the oil pan, for one reason - gravity. I want my oil going downhill, not horizontal or almost, into the valve cover, granted that is easier/closer? In all reality we know that the upper oil pan is the most ideal place, if you have the time/patience or in some cases money to pay someone else..
I would not advise returning it to the oil pan screw though, as this is the very bottom of the system...
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
