Who Has Optima Yellow Top Battery?
For any of ya who have the battery how much did you buy it for? And how did ya install the battery because i heard its bigger than the regular battery and the tie-down doesn't fit? I think Pepboys is selling it for $109.
Re: Who Has Optima Yellow Top Battery?
I got a really good deal on mine. I paid $45 each for 6 Yellow tops. I met a guy that was using them for EV testing. Batteries were drained and recharged only 3 times over the course of month. Four of my buddies got there yellow tops from me and I sold two to a couple of org members a few years ago. To this day, not a single one of them has had a problem so far. I'm curious to see how long this will last.
Go to www.optimabatteries.com to read the differences. I just know that the yellow top is better for people that use a lot of power at one time.
I just put a piece of plywood wrapped in plastic (to keep moisture out) under the battery.
Works great.....
paid $159 for mine....now I feel like I got raped. Too bad there's no Pep-Boys in Seattle.
Works great.....
Originally posted by johnvt1111
i know this could be slightly off topic, but which is better, yellow or red top batteries?
red top is more of a powerful starting battery (more CCA) for little to no aftermarket electronics.
i got my yellow top for $190 canadian under a group deal
that comes out to like $130USD so you have an amazing deal on your hands.
Originally posted by meccanoble
whats the minimum amount of electronics u would recommend using for a yellow battery?
2 subs, 2 amps, underbody kit?
what combo is good for the yellow?
off of my battery I have two tv's,psone,vcr,underbody neon,stobes,fog lights,
I have run my system at shows for up to 3 hours no probs at all...
Ravq
Are you using the stock tie down?
no.....my car never came w/one so I don't have one...
Yes I am but I had to add a rubber washer underneath the tie down where it makes contact on top of the battery due to the large bulge right where the tie down makes contact. It just doesn't allow the tie down to sit level. What about you?
Originally posted by metallic97gxe
ravq
http://www.nissanx.net/gall/alb/Pics...rill.sized.jpg
ravq
front battery
rear battery
It's not secured at all? Just don't go running over any potholes...
no it's just sitting there holding it's own...
new pic as of today..
http://www.nissanx.net/gall/alb/Pics...0064.sized.jpg
Ravq
Ravq
yellow top good for when car is off
alternator good for when car is on
a friend told me that the battery is only good for people running a lot of electronics when the car is off. When car is on, a good alternator is recommended...is this true?
our stock alternators are pretty good already...
The yellow top is a deep cycle battery. The value of this battery is for when/if you have an extensive audio system and you play it for long periods of time with the car off, such as when competing at audio shows or if you like to jam while detailing your car. If your car is running, your electrical system is being fed by the alternator. The only time the battery comes into play is when the car is off or you draw more amps than the alternator can supply. Needless to say, you have to have a serious audio system to necessitate an upgraded alternator. I've had your average two amp systems in several cars and never needed the alternator upgrade. The red top is a robust battery. It's like a normal battery but better. I've known a couple of people who said they have used them as long as 10 years with no problems. If you need a deep cycle, get the yellow top. If you don't, you could ge either way and not hurt anything. I bought mine from Advance Auto and the yellows and reds were the same price.
I'd like to make a corrective statement. If your car is running, the alternator gives power only above a certain RMP level...generally 1,500-2000 is the minimum RPM's at which you are actually using electricity from the alternator, not the battery. Hence when you drain your battery, get a jump, and then have to drive around for 30 mins on the highway.
Originally posted by SKY----------
I have a BLUE TOP running two ROCKFORD FOSGATE AMP 600 WATTS.
GET A BLUE OR YELLOW TOP.
Is it true the yellow top is at Pep Boys. To the best of my knowledge they only care red top Optima batteried. Red tops run aroun 110, yellow top around 180. Correct me if I am wrong. I think there is a lot of pricing and availibility misinformation going on in this thread.
bigfrank
Oct 1, 2015 12:51 PM
