SC sounds like a can full of nuts & bolts
I started my car up this morning to warm up and it soulded like some one was rattling a coffee can full of nuts and bolts. I shut down the car and looked at the SC and nothing looks out of the ordinary. I started it back up and the same thing. It is coming from the SC. Befor today you could not tell that i had a SC (by sound). It runs fine, pulls hard but sound like hell.
Is mt SC going bad? What's up?
Re: SC sounds like a can full of nuts & bolts
Does it make that sound when you rev it up above idle, or does it go away, like the V1 noise at idle?Try to locate the sound by getting a mechanics stethoscope from Autozone. Maybe you will be able to determine if it is a blower bearing or just an idler pulley bearing, or even something else altogether.
WizzaMax: Yes the belt jumped on Sat. I loosened it up and moved it back in place Sun and this morning it started. It was fine Mon, Tues & Wed.
maxi-overdose: Yes it does sound similar and it gets louder when you give it the gas. But then seems to go away...or i can't hear it anymore because of the other sounds that go on.
Stephen Max: It's coming from the SC (95% sure)
I have had a grinding noise on the V2 SC ever since I got the damn thing so I thought that I had a defected blower. Well, I sent it back to Vortech and they checked on it and said that nothing was wrong with it. I install back in and I had the same noise going on again. BTW, it took like 3 months to get my charger back. I was ****ed! But anyways, now I am thinking that it is supposed to be like that. At idle it sounds like something is grinding bad in there, but once I start to give it gas, it goes away and u hear a tiny little whistle which IMO sounds hella tight! I am still unsure if my V2 is okay or not. Could my belt be too tight? I'll tell u this though... my Max runs hella good. Well, let us know what u find out.
AC
AC
And here it is!
http://www.cyberhub.net/scsound.wav
Mine always makes the sound a little - but I have the V1 - and it's not NEARLY as loud as what BlackCat's sounded like (link above).
lowpost99
Oct 26, 2025 06:53 PM
