HELP: melted spark plugs stretched coil !!
Old Mar 7, 2003 | 09:01 PM
diegomax's Avatar
Help me man!
Im relacing my old Bosch spark plugs (I know .. I know)with new NGKs. The Boshes start coming out looking really bad. As i pull the ignition coil from the third cylander, the coil sticks to the spark plug head, and my dumb *** keeps tugging. The inner coil of the ignition coil is stretched out of the housing. Is this coil f***ed??.
I look at the bosch spark plug. the non sparking end has melted and TILTED and had snagged the coil contact point.
The fouth cyclander coil is stuck too. i dont want to ruin two coils. what now.
1. Can i drive the max with 1 pug and 1 coil unatached? (at all?)
2. how much are new coil packs?
3. could I jst cut the extended stratche4d coil and re install it. or is that a recipor for total diaster?!
any ideas or help !
thank guys
Old Mar 8, 2003 | 12:16 AM
Chunger's Avatar
My other car is a Hybrid
You can run on 5 cylinders if you "have to" for short distances. Make sure you disconnect the harness from the coil pack.
They run about $80-100 each.
Old Mar 8, 2003 | 06:41 AM
cbr2's Avatar
i got coils off a 70k car.. I'll sell them for $30 each shipped of $110 for all 6 if you end up needing them.
Old Mar 9, 2003 | 12:36 AM
Chunger's Avatar
Just as a note:
You can't drive it long this way (no ignition to cylinder)... the unburned fuel will overheat your Catalyst and destroy it...
Old Mar 10, 2003 | 10:40 AM
diegomax's Avatar
problem solved
So i am following up my own post hoping that it may help others down the line.
Firstly. I didnt have to replace any ignition coils after all. just as I was ready to dish out for 2 new coils, (as the contact coils appeared to be stratched out of the coil pack housing) I decided to disassemble a coil pack, and to my genuine surprise, there's nothing to them. I tugged to seperate the long coil housing from the transitor?, and the contact coil just fell right out. (a good thing) So i just stuffed the coil back in to the housing throught the top, and it was a good as new.
Now the lesson learned. I know it has been said many times before... but seriosly folks. Bosch spark plugs dont do well in the VQ30. of the six bosch plugs that I pulled from the engine (after 20K miles). 2 where so severly melted at the contact end that they had snaged on the ignition coils causing my panic. 1 spark plug had no electrode left. NONE. the spraking prongs had been cooked away.
SO thelong and short:
NGK platinums ONLY!!!!
If your ignition coil packs have issues dont be affraid to pull them apart. they are fairly simply devices.
thanks for all your help gang
jmlee44
Oct 2, 2022 02:13 PM
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
