clutch slave cylinder part 2
It's not the slave cylinder, I found out. The release lever, or whatever it is that the cylinder piston pushes in, does not spring back out, which doesn't push the cylinder piston back in, which doesn't push the clutch petal back in. which is why when I pumped the clutch petal it sprayed brake fluid across the street. you can take that release lever and move it back and forth effortlessly. I guess I'm screwed now and need my clutch repaired?
Re: clutch slave cylinder part 2
As a kit, they usually run about $100 - $150...the labor, however, could be high, as they have to drop the tranny out of the car.
Re: Re: clutch slave cylinder part 2
Originally posted by MaxWgn
Yes, it sounds like you will need a new clutch, pressure plate and throw-out bearing...
S
!?##@^&ing !?@#$% !?#@$ mother!?#@$%
what can I look to spend to have this repair done? nobody wants to give me a specific estimate because they don't know what's wrong.
S
MAXSE5SPD
Sep 17, 2022 04:00 AM
MR2 T'd
Jul 9, 2021 05:06 AM
