SC Pre-Install Install questions
Old Mar 17, 2003 | 10:14 AM
ejj's Avatar
ejj
I'm trying to come up with everything that I can install this upcoming weekend before I tackle the major work involved in the project.
PS lines - Sounds simple enough (in concept). You remove the aluminum ones, correct? What do the instructions refer to when they say to "cycle" the PS rack?
Fuel stuff - I already have a walbro installed, so I'm not going to be using the aux. pump. So I can install the FMU now, correct? Is the following the correct fuel flow: FRP OUT -> FMU IN -> FMU OUT -> Return line
Boost guage - I'll be a true ricer and monitor my vac. for a week.
Anything else you guys can think of that I can do before the actcual install?
Old Mar 17, 2003 | 10:35 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
1) Remove the aluminum ones that are in the engine bay. I never received the one that sits in front of the condenser, so I just reused it. No clue what "cycle" meant.
2) Correct. Yes, you can install that now.
3) but time of completion will be that much sooner.
You can move the horns, setup the stand-off bolts, put the camshaft retainer in, move the relay box back, relocate the coolant reservoir, and wire the electrical stuff.
Old Mar 17, 2003 | 10:44 AM
ejj's Avatar
ejj
Thanks. There isn't any electrical stuff if I'm not using the aux pump, correct? Either that or I missed something!
Old Mar 17, 2003 | 10:49 AM
Stephen Max's Avatar
Re: SC Pre-Install Install questions
Cycling the power steering just means to remove any air that might have entered the lines. You do it by turning the steering wheel all the way left, then all the way right, and repeat several times. You will know when to stop when the whining noise from the ps pump goes away.
In addition to what y2kevse said, you can also install the thermostat housing that came with the kit and the water pump cover with the oil return pipe. Seal off the end of the pipe with a rubber stopper or something. Now would be a good time to replace radiator hoses, too.
Old Mar 17, 2003 | 10:50 AM
ejj's Avatar
ejj
Re: Re: SC Pre-Install Install questions
Thanks. That's kinda what I figured.
Old Mar 17, 2003 | 10:54 AM
Y2KevSE's Avatar
D'oh! Sorry... short term memory (or unable to comprehend what you wrote in #2).
Old Mar 17, 2003 | 11:13 AM
WizzaMax's Avatar
Relocate the fuse box
Move alarm horn
Clean junk off of fitting area on back of oil pan
Remove PS hardlines (they are not reuseable in my case)
Install new cooler lines and just turn left to right with top of cylinder open to top off fluid to cold level.
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
