splitfire spark plugs
Old Jan 15, 2001 | 12:37 AM
MrBurner's Avatar
hey, i can get some splitfire spark plugs for free...are they better or worse than stock? i don't particularly want to fork over $12 each for the denso's...i also plan on putting on msd spark plug wiring
Old Jan 15, 2001 | 12:41 AM
punkdork's Avatar
Is there any performance to be had in upgrading the ignition syste, at I'll. I'd do it, but not for 2 hp.
Old Jan 15, 2001 | 12:47 AM
MrBurner's Avatar
i've heard the densos add 5-20 fwhp (i know, hard to swallow for spark plugs) and that with big wider msd performance wiring should add quite a bit...i'm thinking 10 + hp all together...the only problem is that the densos at the cheapest are $12 each x6 = $72 and the msd wires are $80 at checker...total around $150 plus it takes about an hour or more to install it all...i'll probably do it sometime down the line when my stock sparks ware out a little more
Old Jan 15, 2001 | 12:53 AM
punkdork's Avatar
$150 for 10hp isn't bad. Look at the price on a y-pipe. I'd do it. Can anyone confirm these numbers?
Old Jan 15, 2001 | 01:13 AM
MrBurner's Avatar
punkdork, i'm just getting into the sig on this site...how do you make it in a list like yours and how do you make the text smaller?
Old Jan 15, 2001 | 02:00 AM
punkdork's Avatar
Write a table in html (thats what I use with borders set to 0). You also want to have no extra line-breaks or spaces in the html or you will get a lot of empty space above your sig.
As far as fonts, use the SIZE= propterty of the FONT tag.
Old Jan 15, 2001 | 04:30 AM
wdave's Avatar
Splitfires are very good fishline sinkers! They are even cheaper made than Champions. They have a bridge to sell you cheap too.
Dave
Old Jan 15, 2001 | 08:16 AM
2Maxed-out4u's Avatar
Where can I go to buy these densos? (What website)
Old Jan 15, 2001 | 12:20 PM
NYC2SD's Avatar
Don't we have direct ignition? meaning no wires??
Old Jan 15, 2001 | 12:37 PM
MrBurner's Avatar
o, possibly, i haven't checked on the wires yet...i just know they sell some msd's at checker
for the densos i think the cheapest place is https://key.2coolweb.com/monarchprod...cartindex.html
Old Jan 15, 2001 | 12:47 PM
UMD_MaxSE's Avatar
Got Bent?
Yup... We have a direct ignition system. No plug wires.
Old Jan 15, 2001 | 04:26 PM
Jeff92se's Avatar
I'm needing a caw
Ugh.. No freakin' spark plug is gonna give you 10hp. There are no ignition upgrades(that work) for the maximas that have the direct ignition systems. 92-94se and ALL VQ powered maximas. If 10hp was possible from spark plugs I would have did it years ago. It's actually ALOT easier to LOSE hp from choosing the wrong plug. Just buck up and get the factory ngk plats from courtesy nissan. Anything else is a bad bet. NOTE: plugs for the 5-gens are at least a 60k interval change.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
