Piccs of VQ35DE internals
Old Mar 22, 2003 | 07:51 PM
MardiGrasMax's Avatar
http://members.verizon.net/~vze4yqyk...m_a_2002_m.htm
If some one wants to link them all, go right ahead.
Old Mar 22, 2003 | 07:57 PM
Cumalittle
Re: Piccs of VQ35DE internals
visually...both blocks seems 90% + identical..of course i don't knoe shiet....
Old Mar 22, 2003 | 08:24 PM
xHypex's Avatar
Looks good
Does it look like everything is going to fit together pretty easily? Any idea on a final displacement? I've read the hybrid 3.0/3.5L -> 3.3L discussions, but I haven't heard anything about it in a long time. The next weakest part is the block too right?
-hype
Old Mar 22, 2003 | 08:27 PM
MAXIN's Avatar
interesting...
Old Mar 22, 2003 | 08:34 PM
gtr_rider's Avatar
192.168.1.1
My mY
Old Mar 22, 2003 | 08:56 PM
SR20DEN's Avatar
VQ Wizard
Thanks Matt.
Old Mar 22, 2003 | 09:04 PM
SR20DEN's Avatar
VQ Wizard
Originally posted by xHypex
Looks good
-hype
The final displacement will be 3498cc's unless he bores the thing out .5 or 1 mm. He's using the VQ35 block and crank.
+ 0.5mm = 3535cc's
+ 1.0mm = 3572cc's
It certainly does need a deck cap for high HP applications.
Old Mar 22, 2003 | 09:18 PM
ChillWill2000's Avatar
You can really see the size difference of the 2 with the picture of the gaskets side by side.
Good Pictures
Old Mar 22, 2003 | 09:48 PM
SR20DEN's Avatar
VQ Wizard
A few conclusions
1.) Notice the VQ35 cam lobes are cut to 1/2 thicknes on the preload side to reduce friction. The VQ30 cams aren't like that. This is one of the thigns I noticed on mine when I took the valve cover off.
2.) It looks as if the VQ35 cams can be used on the VQ30 head which is good because it's more aggressive.
3.) The VQ30 cam cannot be used in the VQ35 because it has no timing ring on it for the ECU to read.
4.) Nissan still isn't using oil spray jets from the block to cool the pistons. They're still using an oil spray orifice on the connecting rod to do this job instead. I wonder if there is avery good reason for this or are they being stubborn.
5.) The intake ports on the VQ35 head are not obviously larger than the VQ30 head but they are shaped differently. This would mean that the lower intake manifolds are not interhangeable between engines. A picture of a VQ30DE-K needs to be compared with these.
Got any crankshaft pictures??
Old Mar 23, 2003 | 05:22 AM
The block does have under piston oil spray jets, I removed them when I pulled the pistons out.
The cams from the vQ35 will fit in a VQ30, but unless you use the variable cam control the power band will be off.
Crank, its in a box under allot of stuff, gimme a little while.
Rods look pretty whimpy though
Old Mar 23, 2003 | 02:20 PM
ejj's Avatar
ejj
Which VQ30 are you using to create the new engine? Did you get a used one, or the one that you purchased and had problems with?
Old Mar 23, 2003 | 05:15 PM
I am using VQ30 heads from another motor.
Old Mar 23, 2003 | 05:25 PM
SR20DEN's Avatar
VQ Wizard
Are there any shops nearby that would have a flowbench?
Old Mar 23, 2003 | 05:28 PM
SR20DEN's Avatar
VQ Wizard
Let me remain in denial.
Old Mar 23, 2003 | 06:32 PM
Prolly, are you buying?
Old Mar 23, 2003 | 06:36 PM
SR20DEN's Avatar
VQ Wizard
For the flowbench time? I could be persuaded to split the cost if not too much.
Old Mar 23, 2003 | 06:38 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Mardi,
Still going for 3.8 liters? If so, what are you going to do about the cylinder wall? Isn't it too thin to bore out that much?
I want to be the first one to hear a sound clip of your car if you succeed in that.
Old Mar 23, 2003 | 06:52 PM
Sprint's Avatar
http://www.sprintmax.com/othercars/v...Engine-Project
I will pm you a username and password for you to upload if you like
Old Mar 23, 2003 | 07:01 PM
SR20DEN's Avatar
VQ Wizard
HAHA you too? I mirrored his stuff here already.
Old Mar 23, 2003 | 07:17 PM
redmaxpa007's Avatar
i SeE what you did therE
wow..
Old Mar 23, 2003 | 07:19 PM
Sprint's Avatar
Originally posted by redmaxpa007
wow..
"what should we do tommorow brain"
"tommorow we do what we try to do everynight.. try to take over the world"
Old Mar 23, 2003 | 07:25 PM
yes darren... what is it?
Old Mar 23, 2003 | 07:26 PM
SR20DEN's Avatar
VQ Wizard
LOL... took me awhile to pickup on that one.
Old Mar 23, 2003 | 07:32 PM
Sprint's Avatar
Old Mar 23, 2003 | 10:04 PM
MrGone's Avatar
do they seriously go on metrics for the motors?
if you bore it to far you can always sleeve it, just worry about hot spots in the walls.
one thing that is going to suck is the cost for a gasket set
if you find a good deal on one, please let me know, i need one for a VE.
good luck on the project. I dont think you can get too much more out of the heads and just watch out for the swirl patterns.
MrGone
Old Mar 24, 2003 | 05:37 AM
96BLUMAX's Avatar
Wow thats phat. Just went to your website and say the list of new stuff, the new dyno results and the new track run. Congrats! Now maximas are actually really freakin fast. I guess i missed a lot while i was away from the forum.
Old Mar 24, 2003 | 05:40 AM
ejj's Avatar
ejj
What compression is this engine going to yield?
I assume you're going to use it with the SC?
Old Mar 24, 2003 | 06:32 AM
I will be bored just the normal .020" over, trivial for displacment but important for a quality build. The heads will stay for the most part stock, perhaps some heat rejection coatings on the valves. Forced induction and nitrous does not really require the extra money to be spent on head work and cams, like NA would. Sure it would help a little but for the cost just juice it or boost it more, the question is the strength of the rods, pistons, head gasket etc. I am leaning toward o-ringing the head with a copper gasket, but with head studs and the factory MLS head gasket I might be ok. Or hopefully HKS or NISMO will come out with a solution for the deck issue. Rods, pistons, wrist pins, rings and ARP fastners including main studs and head studs instead of bolts are in development. The CR will end up ~9.3:1 with VQ30 heads, using what would be 8.5:1 pistons inside a normal VQ35 with VQ35 heads. 9.3:1cr will be pretty good for me I think. I'm in no rush, my goal is to have it ready to run for the winter.
Old Mar 24, 2003 | 06:37 AM
SR20DEN's Avatar
VQ Wizard
I agree thats the next best thing to getting a deck cap. Be careful with the copper head gasket though. I hear tales of people saying they leak and arent good for the street. You could get the block o-ringed which may be even better.
Old Mar 24, 2003 | 06:39 AM
Lime's Avatar
<grabs cams>
Really neat pictures! Thanks!
Old Mar 24, 2003 | 06:54 AM
MrGone's Avatar
for the copper head gasket seal problem, has anyone tried painting them with some High temp spray paint?
also if it is just leaking coolant, some high temp copper rtv should do the trick, just create a small bead around the water holes.
MrGone
Old Mar 24, 2003 | 07:02 AM
SR20DEN's Avatar
VQ Wizard
MrGone
I wouldn't put RTV on the head gasket unless it was a tiny dab of copper. I have seen them use copper RTV on top fuel motors with copper gaskets.
Old Mar 24, 2003 | 11:10 AM
MrGone's Avatar
Id put it on like you would put Artic Silver thermal compound on a processor, paper thin. just enough to seal the itty bitty gaps that would be causing leaks. I had a feeling using the word "bead" would probably sound like alot, which I suppose it technically is.
So is this going to be a boosted motor?
MrGone
Old Mar 24, 2003 | 11:37 AM
SR20DEN's Avatar
VQ Wizard
MrGone
Now Arctic Silver might work great.
James92SE
142
Jan 2, 2024 09:23 AM
6spd4dsc
Mar 4, 2016 05:19 PM
