springs/struts and WHAT ELSE?
Re: springs/struts and WHAT ELSE?
Originally posted by skeetsmax
When I go to lower my max what else is crucial for the job? I know that you will need springs and struts..duh... BUT what else is there some bushings or anything else????
Also you should at least replace the front strut bearings and the mounts (front) and rubber isolators (front and rear) (the front one is inside a metal piece that sits inside the mount.). If those go bad, you end up pulling the struts and compressing the springs again to fix them. Use stock Nissan parts for those as many have had bad luck with these kyb parts.
I hate re-doing a job because I didn't replace something I should have...
Good luck,
Jim
You dont need no damn spring compressor, its fun watching stuff shoot across the room
When I lowered my car I didnt have to buy anything other than the springs and struts and wire wrap so there is no noise! It works fine.
RapidMax
Aug 1, 2004 09:01 PM
