Common problems list needed - Buying used gen 4
Old Mar 26, 2003 | 11:07 AM
chavvez's Avatar
I'm in the market for a used gen 4. What are the common problems I can expect to have and what should I be on the look out for when looking at used Maximas?
Old Mar 26, 2003 | 11:19 AM
JSClark's Avatar
Well, you will wanna make sure the alternator recall is done to the 4th gen. What happened was the alternator wasn't built properly for the 4th gen, and those have been known to catch on fire (as far as I know). Other than that, I can't really think of anything else...
Old Mar 26, 2003 | 12:21 PM
waveridr85's Avatar
how do you know if the alternator was done
Old Mar 26, 2003 | 12:24 PM
matty's Avatar
If its a 5speed, a comman problem was differential bearings going bad inside of the tranny cause a leak out the drivers side axle...Look at the previos repair records and see if the axle seal was replaced at all under warentee (usually nissan wont rebuild the tranny, they will just keep doing the seals, until your out of warentee then hit ya with a tranny rebuild)
-matt
Old Mar 26, 2003 | 12:26 PM
hokiemax's Avatar
what kind of mileage are you looking at here?
I've had my maxima for 135k miles and didn't have any problems.
Old Mar 26, 2003 | 12:43 PM
joew's Avatar
is it all 4 gen max include '97?
Old Mar 26, 2003 | 12:45 PM
ejj's Avatar
ejj
Was that a sentance?
I'm pretty sure the recall was just some 97's. Your dealer or Corporate Nissan can tell you if you need the recall by your VIN.
Common problems? I have yet to have a single problem between the two maxima's that I've owned (97 GXE and a 99 SE). I drive 'em hard, race 'em, etc, no problems.
Old Mar 26, 2003 | 12:55 PM
chavvez's Avatar
It is a 95 GLE auto with approx 100k. If the alt. problem was a recall the dealer has to fix it for free right? Thanks for the help so far.
Old Mar 26, 2003 | 01:03 PM
ejj's Avatar
ejj
Correct.
However, because its a 95 auto, neither the alternator or transmission bearing problems would apply to it.
Old Mar 26, 2003 | 01:08 PM
Maxima95Tuner
The only common problems Ive seen on my 95, my mom's 96, and my neighbor's 96, is that the pump for the windshield wiper fluid went out on all of the cars. Other than that, the only thing Ive had to replace was my power steering pump.
Check for leakage around the PSP. If you can see / feel the fluid leaking out, you will prolly have to replace it eventually. I drove with a leak in mine for a long time, but eventually you will lose the fluid and lose your power steering.
Old Mar 26, 2003 | 01:34 PM
Eric L.'s Avatar
Not sure if the signature function is working, but if it is, you can read all the parts I have replaced. The major problems on 4th gens would be alternator (there was a recall) and there is a starter problem as well (i predict nissan will issue a recall).
Other than that, the car is pretty much bullet proof.
Old Mar 26, 2003 | 02:48 PM
slavik'sMAX's Avatar
Actualy looking at the eric L.'s sig I had pretty similar parts replaced on my '97 (at the heigher milage though):
Oil pressure sending unit
HVAC blower unit
LH bank O2 sensor and afterCAT o2 sensor as well
starter
antena mast
so I am not sure if these are common repairs, but I was just suprised at similarity
Old Mar 28, 2003 | 08:25 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
even some '98s up to March '98 (approx.) were affected by the recall, the alternator on my former '98 SE was replaced by the recall since it was manufactured on Jan. '98
Old Mar 28, 2003 | 10:47 PM
vipervadim's Avatar
I like Maximas
99's have been known to have faultier ignition coils, but i have 61k on mine and they're ok. otherwise it is a beutiful car! i know i love mine!
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
Slamrod
Aug 10, 2015 12:33 PM
kirkhilles
Aug 8, 2015 10:53 AM
