changing corner bulbs
Old Mar 26, 2003 | 07:50 PM
masterB's Avatar
i'm trying to change my corner bulbs, the one that next to the main headlight.
my question is after I took the screw off from the top of the housing, I try to pry it open like the manual says, but there is a socket like thing at the back, no matter how hard i pull it won't come off.
am i doing anything wrong or i have to keep pulling harder??
Old Mar 26, 2003 | 08:29 PM
Torgus's Avatar
i want to know too...BIZUMP!
Old Mar 26, 2003 | 08:47 PM
Nismo's Avatar
thers a ball in the back of the light thats snapped in a socket which you have to pop out of to remove the corner light. I was able to change the bulbs without removing the light because I didnt want to remove my eyelids. you have to take out the turn signals and its really hard to reach up and I got a few cuts to prove it.
Old Mar 26, 2003 | 08:50 PM
masterB's Avatar
the ball socket is like impossable to pop out..
Old Mar 26, 2003 | 09:01 PM
cscm094's Avatar
No it isn't... I popped it out on my 95. Just pry and pry and pry some more then it should come out. Be careful not to break the light though.
Old Mar 26, 2003 | 09:20 PM
95emeraldgxe's Avatar
shove a flathead in between the headlight and the parking lamp(preferably with some cloth on it to prevent damage) and then put shove the flat head on the other side and pry it out a bit more, and then with a firm and even grip on both sides - RIP it out, but make sure its even pressure, cause if its not, your going to break the mount on the back........again your going to have to put in ALOT of force into it
Old Mar 26, 2003 | 09:55 PM
Max-2-GTR's Avatar
just get a flathead screwdriver inbetween the socket ball and where it's in and turn the screwdriver, the socket should pop out by itself
Old Mar 27, 2003 | 06:10 AM
Dasyce's Avatar
thats exactly how to do it..
if u try to pop it off using the nissan instructions or if u try to pry it off with the flathead screwdriver u'll end up damaging the corner light..
Old Apr 2, 2003 | 04:15 AM
pruizgarcia's Avatar
Spary some WD-40 on the socket and let it soak. That is how I was then able to use the flathead screwdriver to jiggle it out.
Pedro
Sir Tilus
Mar 22, 2016 01:49 PM
Blkkn8
Sep 22, 2015 06:37 PM
JoshG
51
Sep 21, 2015 10:41 PM
meccanj98
Sep 16, 2015 06:06 PM
minsbang
Sep 11, 2015 08:48 PM
