99 SC bracket
Old Mar 31, 2003 | 02:35 PM
furbiss112's Avatar
99 SC bracket
well i went ahead and tried to see if it was going to fit on my built 97 max motor. it lines up perfectly. everything fits just where it is supposed to. therefore, stillen is so bull****ing about the different brackets for the 99 and the 98 and older. i will know if there are any belt issues by the end of the week. htat is when we should be able to bolt all the pumps and pulleys and drop it in the car. later.
Ferhan
Old Mar 31, 2003 | 03:30 PM
ejj's Avatar
ejj
Interesting...
This is a 99 kit on a non-99 correct? Wonder if they are problems the other way? I remember reading about someone who had problems...dunno who though.
Old Apr 1, 2003 | 01:54 PM
furbiss112's Avatar
99 kit
my kit is for my 99 maxima. i am putting it on my 97 built motor. all bracket bolts line up. all spacing line up. only i need to confirm is, the blet alignment. which i am pretty sure will line right up. no modifying is required to mount the bracket. later.
Ferhan
Old Apr 1, 2003 | 03:46 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
The bracket should be the same for the 2k-2k1 also.
Old Apr 2, 2003 | 07:37 AM
furbiss112's Avatar
2k and 2k1
the bracket on the 5th gens in the same they sell for the 99 kit. therefore theey are the same. later.
Ferhan
Old Apr 2, 2003 | 09:39 AM
SighMax's Avatar
Maxima Enthusiast
Re: 99 SC bracket
The contact point on the bracket to the timing chain cover on the '99s are narrower than the previous years. If you use the previous year's bracket on 99, you may crack the t-c cover and it will start leaking oil. I don't believe there are any other major differences including all the contact points. Therefor, you should be able to use the 99 bracket on the previous year engine. You can probably use non-99 bracket, but the stress caused by the contact point will eventually crack the timing chain cover.
Ferhan
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
followthadollar
Sep 22, 2015 11:53 PM
jcvgn
Sep 13, 2015 11:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
