How long have people's stock batteries lasted?
A couple of weeks ago my battery was dead one morning. I jumped it off, drove it around for a couple of weeks, and this morning, she turned over a couple times, and was dead again.
I'm suspecting the alternator here, but just wondered if it's worthwhile to get a new battery while I'm at it.
I'm on about ~40k miles on my '97.....
well when I took a meter to it, only had 11.75 volts or less. put it in the maxima (swaped the red top to the crx thinking it may be the battery, but it wasn't) with less than 12 volts, cranked up the maxima in first try.
Optimas are costly but worth it... plus wiht 800+ CCA, you shouldn't ever have a problem starting the car.
-Shing
Mine lasted a little over a year ->
I did put over 40K miles on the car =) I bought a Optima orange top battery two weeks ago. If you decide to go with Optima, the battery is too short for the OEM J hooks. You either have to raise the battery up by using a platform or get new battery hold down J-hooks. The J-hooks are the two J thingy with threads and the nuts on it. There are not enough threads so the nuts won't go down for enough for a shorter battery. You can pick some new 6" ones at Trak Auto that has the more threads so that the nuts can go down far enough to hold the battery snug. That's what I did.
Re: 110,000 miles
WOW, 110,0000 miles, and I thought I was doing good. I have 58,000 miles on mine and can tell that I might have to replace it within a year and a half. Not too bad considering the cold weather here in Colorado.
Originally posted by Whitemax
Yup. I changed it just because,
if the dealer didn't pull my leg
about 31 months. I got the spare in my trunk (needs to be charged up). But my car sat for one week at the airport and she started right up without problem. Even the windows were iced shut. Dealer said it failed the load test.
My OEM battery lasted me about 1 week after I signed the papers on the car in august of '97 (so the oem battery lasted about 4 years). After that, I dumped in an Interstate battery, and I've sent it through hell and back over the last 2.5 years.
Re: 110,000 miles
Similar to MaxSpeed5, my OEM battery was still going great on my 95 with 100K. I changed it only b/c my wife began driving it occasionally 200 miles one way on rural roads with my infant son. For $45, it's cheap insurance...
my stock battery was not dying on me, but started leaking, so i changed it at 35,000 miles.. i wussed out and got the cheapo battery at costco.
my dad's GLE has over 78000 miles on his stock battery...
I just put a new one in my 91GXE which I bought in '95. Assuming that the dealer had put a new one in it before I bought it, I got more than 5 years out of it.
I put a new one in my '95, before I realized it was the starter that went bad at around 60k miles.
Seems to me that 40k on a '97 is too soon for it to die.
Jim
Jim
Your Alternator
Albert--
what's up man? Happy new year!!
when did you get your alternator replaced, and where?
I am not having any of these problems yet (knock on wood)--but how did you know that it was your alternator?
thanks--
Brian
thanks--
Brian
Originally posted by Albertt
It'll probably die soon...I had to replace my alternator a few months ago. When the battery dies, I'm getting an Optima.
stock battery
i had to replace mine after 2 years. because i let 1 cell go low. if i had kept an eye on the electrolite levels it would have lasted longer. i like the optimas also, i also like the small size gel batteries.
I drove the car home from the dealership and when I tried to start it later on in the day, it wouldn't start. So I guess you could say it lasted 30 minutes. The dealer brought another one to my house, but I couldn't believe that it died.
short trips
question for everyone--
is it true that when your car does a lot of short trips? which mine does--usually in the morning--1.5 miles and then in the evening for 1 mile--and that is about all the driving the car sees...Does that hurt the battery or the alternator, since there isn't a lot of recharging? is that the theory of it?
can anyone explain a little of this?
Originally posted by costcowholesale
I have a 99 GLE 21000km that does lots of short trips
think I have to replace the battery soon? like in the summer? oh yeah I live in canada toronto lots of horrible winter here
Superbform
Aug 11, 2015 08:10 PM
