Dunlops SP A2s vibration
Yesterday I bought 4 new Dunlop SP A2's from Sears.....I was able to get a bit of a discount as they matched Tire Racks price BUT they also insisted on adding the price of shipping. Still came out a bit ahead. Anyway, they had them in stock and I was the first person in the store so it was quick. They mounted, balanced and installed new valves and stems. Everything pretty good so far. BTW, went with the OEM tire size 215/55/16s. Left the store a happy man. That day driving around in town very nice. Going home on the freeway though the steering wheel began to vibrate at 68-70 miles. This is very unusual. The steering on my Max has always been rock solid. No pull, no vibration. Also the tires that I replaced, Michelins MXV 4s with about 50K showed very even wear. I really don't think that it is an alignment issue. Yes there was still tread on them but it was just about to the wear bars and in the rain I was noticing some hydroplaning. What to do? I plan on checking the tire pressure this am before I go out. Then it's out for another test drive. If it happens again I think I'm back to Sears. I have read reports on Tire Rack survey page of these tires being out of round and having problems like this. Man, why me? Any help would be appreciated. Cheers
Originally posted by slavik'sMAX
I am guessing you lost a couple of the wheel weights that they use to balance the wheel...........go back, let them redo the balancing
. Cheers
Originally posted by zagato27
Yes, might be the problem but I didn't notice that "clunk" when you throw a wheel weight. I'm heading back there after I have lunch at school with my 6 yr old
. Cheers
. Cheers
Originally posted by VQdriver
one thing you can try is to remove the wheels and reinstalling them. sometimes if the lug nuts aren't installed properly or the wheel is just slightly off center when you torque it down that can throw things off a bit. use a diagonal star pattern when retorquing. otherwise it's probably a balance issue with the rim and then ultimately a tire defect of some sort. good luck. don't go too long without having the problem addressed.
Originally posted by Velcro
I'm having the same vibration problem with my A2's, I got the tires rebalance and aligned so now the vibration begins @ 75-80mph. let me know if you figure out the problem.
I'm going to ask her very nicely to get the alignment done and then we'll see. I don't have any suspension mods other than a FSTB. How bout you? Cheers
