My Turbo problems, defintely a fuel delivery issue.
Old Apr 8, 2003 | 07:27 PM
BigDogJonx's Avatar
Well finally got around to installing the electronic Fuel Pressure gauge along with an EGT gauge to replace the rainbow a/f gauge.
At idle my fuel pressure shows 33psi. I thought this should be near 50 with the walbro 255lph fuel pump? Or am I totally wrong there?
Now heres the MAJOR problems im seeing. I went for a few sprinted runs.
At 7psi of boost my fuel pressure never got higher than 42psi. Yea thats a problem for sure and then compounded by the fact that I was in 3rd while doing the run and saw my EGT go upto about 1600F. So I cut it immediately. Lord knows if I melted anything, but as far as I know the car runs fine after that. Lets worry about later, Im more concerned about why Im only getting 42psi fuel pressure?
Is it the walbro 255lph pump in the tank that is jacked up? Or is the FMU jacked up?
BTW Im running a t3/t4 turbo, 10:1 Vortech FMU, GSS342 Walbro 255lph fuel pump and all my gauges are Autometer.
Dixit
Old Apr 8, 2003 | 08:03 PM
Confused's Avatar
Permanent Maxima.org Resident
are you running the oem fuel pressure regulator or an aftermarket fpr(in addition to vortech fmu)?
have you checked the fuel lines for kinks and routing in and out of the fmu?
how old is the fuel filter?
Old Apr 8, 2003 | 08:05 PM
BigDogJonx's Avatar
Originally posted by Confused
are you running the oem fuel pressure regulator (in addition to vortech fmu)?
Yes the OEM one is still inline. I just left it there from when I was supercharged, why am I suppose to remove the oem one? I thought you need the OEM one for normal driving without boost and then the FMU Vortech kicks in when we start boosting.
Dixit
Old Apr 8, 2003 | 08:07 PM
Confused's Avatar
that is correct.. i edited top post for other things besides the walbro.. oh,, and check the vacuum lines on the oem fpr and the fmu.
Dixit
Old Apr 8, 2003 | 08:11 PM
BigDogJonx's Avatar
The fuel lines for sure has no kinks since it only goes about 1ft from there to the fuel rail.
Fuel Filter is about 18k. I put the walbro back when it had maybe 14k. Fuel filter on the 5th gens is actually part of the entire fuel pump assembly.
Dixit
Old Apr 8, 2003 | 08:18 PM
sx7r's Avatar
while the car is at idle, pull off the vacuum line from the OEM fpr and see if the fuel pressure goes up. also where did you tap in for your fuel pressure gauge?
Old Apr 8, 2003 | 08:21 PM
BigDogJonx's Avatar
The fuel pressure gauge is tapped on the fuel supply line. I got the fuel pressure sending unit right before it hits the OEM fuel pressure regulator.
So pull the vacuum line off the oem fpr and see if the fuel pressure gauge goes up? Should the car idle wierd at that point then?
Dixit
Old Apr 8, 2003 | 08:27 PM
sx7r's Avatar
Dixit
idle should change for a split second, just put your thumb on the vacuum line to plug the leak.
Old Apr 8, 2003 | 08:33 PM
BigDogJonx's Avatar
Sorry for my ignorance but Im missing you on one thing. If I take this vacuum line off the OEM FPR, then you want to go check the FP gauge inside? Or you want me to remove this line and plug it (which end? the line or the oem FPR?) and then have someone check the FP gauge?
Dixit
Old Apr 8, 2003 | 08:41 PM
sx7r's Avatar
Dixit
ah, don't worry about pluggin it if you're just doin it yourself. all you want to see is if the FPR bumps up fuel pressure when there is no vacuum. so just pull the line off and look at the gauge in the car.
Old Apr 8, 2003 | 10:12 PM
turbo97SE's Avatar
Can't remember if I had asked you this before but how sure are you that you have got the correct fuel pressure regulator? The 2K+ regulators and fuel system are different from 95-99. The most confusing thing is that there is something that looks like the FPR and is located in the same place as the 95-99 FPR but is NOT the regulator. If I have mentioned this before I apologize for the repetition.
Old Apr 8, 2003 | 10:49 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Fuel dampener.
Old Apr 8, 2003 | 11:19 PM
turbo97SE's Avatar
Hehe! Thanks, I couldn't remember for a second.
Originally posted by IceY2K1
Fuel dampener.
Old Apr 8, 2003 | 11:26 PM
IceY2K1's Avatar
No go answer my GT turbo question!
Old Apr 9, 2003 | 06:31 AM
BigDogJonx's Avatar
Still dont know why Im pushing tops maybe 50psi on the FP at 5psi boost. That was this mornings reading coming to work.
Dixit
Old Apr 9, 2003 | 07:00 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Are you sure you are not using the 6:1 disc?
~50 psi is awfully close to what a 6:1 disc would put out at 5 psi boost.
Old Apr 9, 2003 | 08:09 AM
Deac's Avatar
Re: My Turbo problems, defintely a fuel delivery issue.
Dixit
Dixit,
I had PM'd you about this before but you didnt respond. My Turbo is now about 90% done. Yesterday we had trouble w/the Walbro Fuel Pump. I know it is not a direct fit but I have'nt been able to get a straight answer from any 5th Gen guys in months about the install of the damn thing! Anyway... We had a horrible time getting it to fit in the fuel pump unit.... the major issue was that one of the hoses that connects the Walbro to the fuel pump unit, seemed to be getting pinched to where not enough fuel was getting through and the car would'nt start...and the way the mechanism is set-up, there really no way to give that hose enough space to where the fuel can flow through it freely! Maybe I'm wrong I dont know and I need help... Dixit, since you are using the Walbro, maybe you should check this issue as well since you are having fuel flow issues. Kev, Dixit, whoever else has the Walbro installed on their 5th Gen...PM me and let me know the best way to install it ASAP.... Thanx.
Deac
Old Apr 9, 2003 | 08:15 AM
Y2KevSE's Avatar
Can you take a pic of what you're talking about?
Old Apr 9, 2003 | 08:41 AM
PCGuRu2K's Avatar
Re: Re: My Turbo problems, defintely a fuel delivery issue.
Originally posted by Deac
Dixit,
Deac
Check out LatinMax's website. He did a pretty good write-up on the Walbro pump install on his 5thgen
Old Apr 9, 2003 | 09:25 AM
BigDogJonx's Avatar
Dixit,
Deac
Sorry if I never responded, appologize. Now I seem to lose you when you say there is a hose that hooks upto the walbro. When you remove the stock pump, it basically slides out of the plastic assembly and the top part of it has the "tire valve" style end. That is the same on the walbro, you just stick the pump back up in there. There are two tabs that may need to be shaved to resolve the issue of getting it all the way up there.
The bottom of the fuel pump has a small debris filter that attached to it, the one coming off the stock one doesnt fit the walbro, you have to use the walbro one. besides that, I never disconnected any hoses inside the fuel pump assembly except the ones at the top to get it out of the tank.
Dixit
Old Apr 9, 2003 | 09:52 AM
mzmtg's Avatar
Minister of Silly Walks
Shouldn't Hal be able to clear all this up for you?
Old Apr 9, 2003 | 10:07 AM
BigDogJonx's Avatar
His invoice shows a 10:1 was given, now that dont mean Vortech couldnt have made a mistake. I need to open and check it.
Dixit
Old Apr 9, 2003 | 10:25 AM
IceY2K1's Avatar
Dixit
Where did you locate your EGT probe in the exhaust?
Old Apr 9, 2003 | 10:55 AM
BigDogJonx's Avatar
Re: Dixit
Right below the flange off the fedspec header. Basically within 6" of the exhaust flow. Autometer suggest that is the best and a few others recommended it, I know everyone WANTS to have it in the header, but this is where I put mine.
Dixit
Old Apr 9, 2003 | 11:40 AM
4signs's Avatar
Dixit
I had a similiar problem, opened up my fmu and found a restriction.
Old Apr 9, 2003 | 11:52 AM
IceY2K1's Avatar
Re: Re: Dixit
Dixit
Front or rear?
Fedspec header? Did you do a conversion?
Old Apr 9, 2003 | 12:55 PM
BigDogJonx's Avatar
Re: Re: Re: Dixit
Front or rear?
yea front, had to remove the calispec precat as well as change the header to fedspec since the calispec header has a 6bolt flange instead of the standard 3bolt flange.
Dixit
Old Apr 9, 2003 | 01:21 PM
IceY2K1's Avatar
Re: Re: Re: Re: Dixit
Dixit
That's useful information. Have you stated that before?
If so, sorry I didn't catch it.
Old Apr 9, 2003 | 01:27 PM
jdmmax's Avatar
Re: Re: Re: Dixit
on the front it routes backwards, so unless you want a uturned uppipe/ypipe, it must be switched.. then you must move the 2 o2 sensors for the precat, behind the real cat.
Old Apr 9, 2003 | 01:35 PM
IceY2K1's Avatar
Thanks...I've been looking under a 4th gen too much lately. I forgot.
I'm hesitant to move the 02, I wonder if the front manifold could be cut/shortened right after the cat so they 02 can stay in place.
Old Apr 9, 2003 | 01:41 PM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Dixit
Old Apr 9, 2003 | 01:58 PM
BigDogJonx's Avatar
No hesitation needed on moving the O2s, I moved the lower ones to behind the main cat and that keeps the SES from coming on. No problems for sure. Only issue is that I cant put a testpipe in now. If I REALLY want to, then I have to get an O2 simulator or build one to keep the SES from coming on.
Dixit
Old Apr 9, 2003 | 02:08 PM
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Dixit
Dixit
Old Apr 12, 2003 | 02:39 PM
BigDogJonx's Avatar
Alright opened the FMU, definetely had a 10:1 disc in there. But Now I cant remember for the life of me whether there was a spring in the FMU holding the disc back or not? Is there just a ring and the disc in there?
Also I disconnected the OEM Fuel Pressure Regulator vacuum line and I saw the FP at idle go from about 35 to about 43-45psi.
So what we all think it can be now? Definetely running lean on top end even at 5psi.
Dixit
Old Apr 12, 2003 | 04:33 PM
IceY2K1's Avatar
Dixit
Considering you're getting 43-45psi at idle with the line removed vs. 42psi at 7psi, your FMU must not be working.
Double check the lines. Sorry, but I skipped that part of the install, so I can't be much help.
Old Apr 12, 2003 | 04:39 PM
BigDogJonx's Avatar
Considering your getting 43-45psi at idle with the line removed vs. 42psi at 7psi, your FMU must not be working.
http://www.bigdogjonx.com/fullpics/turbo/fmulines.jpg That is the hookup of the FMU
http://www.bigdogjonx.com/fullpics/turbo/fuellines.jpg That is the vacuum lines and Ts and what not.
Also, did the FMU inside have a spring in it? I cant remember for the life of me when i opened my last one with the s/c.
Dixit
Old Apr 12, 2003 | 06:25 PM
delio's Avatar
Dixit
No... no springs. Just the blue diaphragam the thick circular disc and the flat round washer
Old Apr 12, 2003 | 07:20 PM
BigDogJonx's Avatar
Alright, that leaves me to only two things, is the FMU bad or the Fuel Pump?
Dixit
Old Apr 12, 2003 | 11:53 PM
IceY2K1's Avatar
Dixit
It's got to be the FMU.
Again, considering you're getting 43-45psi at idle with the line removed and 42psi at 7psi, your FMU must not be working.
At least that's what I see.
Old Apr 12, 2003 | 11:59 PM
delio's Avatar
But is it hooked up right? That is the question... I don't know enough about the 5th gen fuel system to be able to answer definitively
