My Turbo problems, defintely a fuel delivery issue.
Old Apr 13, 2003 | 06:22 AM
  #41
Y2KevSE's Avatar
Rice Boy in Denial =)
It's hooked up right.
Old Apr 13, 2003 | 11:18 AM
  #42
BigDogJonx's Avatar
Sons of Bit@#$. Now I got to get ANOTHER FMU just to test this theory. This is BS. Sorry for my ranting.
Maybe when I move to ATL I can swap it out with Kirk's and see how it runs and then give it back to him.
Dixit
Old Apr 13, 2003 | 01:13 PM
  #43
UMD_MaxSE's Avatar
Got Bent?
Does it matter that the FMU is tapped after the fuel damper? Maybe you can try to tap it before the fuel damper... probably doesn't matter, but it may be worth a try before swapping FMUs or pulling the pump.
Old Apr 13, 2003 | 01:19 PM
  #44
BigDogJonx's Avatar
Man at this point I got no clue, I know a few people have seen the way Ive hookedup the lines and they all agreed the lines are hookedup correctly.
I dont know if the FMU is bad until I obviously get another one and test it. But when I opened it the little button in the center that needs to move up and down didnt seem to want to go down at all. I thought I remember when I had the S/C and opened the FMU on that, I swear that thing moved up and down when I pressed on it.
Dixit
Old Apr 13, 2003 | 01:22 PM
  #45
UMD_MaxSE's Avatar
Got Bent?
Dixit
sell your Vortech FMU and get a Cartech FMU... that way you get an adjustable FMU and will be able to determine if that was the problem...
Old Apr 13, 2003 | 01:26 PM
  #46
BigDogJonx's Avatar
Then I have to go back and dyno tune again just because of the Cartech FMU.
And I still aint got the answer about if you can remove the OEM FMU or not, someone said the cartech is an inline deal, not like the S-FMU by Vortech where you can remove the OEM FMU.
Also does the Cartech have points on the screw? or do I have to just blindside the measurement?
Dixit
Old Apr 13, 2003 | 01:35 PM
  #47
UMD_MaxSE's Avatar
Got Bent?
I believe that the Cartech will still require the OEM FPR. It is still a boost referenced FMU like the Vortech... only difference begin that it is adjustable. I'm not sure, but I think the Vortech S-FMU allows you to adjust baseline fuel pressure as well...
Old Apr 13, 2003 | 08:35 PM
  #48
hlh0501's Avatar
i'll check mine tonight, i'll get you on aol when i get home to discuss it further, if it is fmu i'll have another to swap it with from vortech.
Old Apr 14, 2003 | 07:21 AM
  #49
Y2KevSE's Avatar
Dixit's fuel setup is correct...
- fuel from tank to fuel rail (fuel dampener)
- return line from fuel rail to FMU (through stock FPR)
- FMU return line to fuel tank
You cannot remove the stock FPR with just the Vortech FMU.
With Cartech you will reuse the stock fuel pressure regulator... but you can use it without the stock FPR.
With Vortech S-FMU, you will need to take out the stock FPR before being able to adjust base fuel pressure.
BkGreen97
Apr 2, 2016 05:47 AM
97_GXE
Sep 15, 2015 06:47 AM
BrandonCause
Sep 14, 2015 10:41 PM
Maxima30
Sep 7, 2015 06:13 PM
