Cheapest Performace Mod
Old Apr 10, 2003 | 04:27 PM
BensMax93's Avatar
I was curious to know what the cheapest performace mod is, since I'm on a tight budget. One of my friends told me that getting an exaust system put in is the cheapest, but I'm not sure...
Ben
Old Apr 10, 2003 | 05:03 PM
AscendantMax's Avatar
Re: Cheapest Performace Mod
Ben
you can always begin with removing that stock air box and replacing it with a pop intake. full exhaust systems ain't cheap. just start with an intake and work your way up from there.
Old Apr 10, 2003 | 08:12 PM
MaximaBalla's Avatar
Re: Re: Cheapest Performace Mod
Old Apr 10, 2003 | 08:19 PM
MaDMaX024's Avatar
cheapest mod? advance the timing. its free.
second cheapest? throttle body coolant bypass..less than $3
intake is third and you'll notice a good difference from it (approx. $40). after that, probably underdrive pulley, removed AC belt and then its on to the exhaust but that gets costly.
Old Apr 10, 2003 | 08:36 PM
EdzMax's Avatar
[QUOTE]Originally posted by MaDMaX024
[B]cheapest mod? advance the timing. its free.
How do you do that? Just curious.....
Old Apr 10, 2003 | 08:49 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
cheapest is stickers...
exhaust by far isn't the cheapest to do
Old Apr 10, 2003 | 09:44 PM
how much gains you'll think he'll see? 10+ HP?
as for how to advance the timing...go here:
http://www.prism.gatech.edu/~gte671n/mymax.html
there's lots of stuff in the how to section.
Old Apr 10, 2003 | 10:05 PM
MaDMaX024's Avatar
[QUOTE]Originally posted by EdzMax
[B]
loosen dist. bolts, turn in proper direction the specified amount, check with timing light..there ya go..obviously i know nothing about VGs.
on a VE, you loosen CAS, turn toward the rear of the car, tighten and call it a day.
Old Apr 11, 2003 | 09:04 AM
Lordrandall's Avatar
FSTB or RSB
Old Apr 11, 2003 | 09:10 AM
ObsidianIce69's Avatar
hey fellas you missed the important one! if you're driving a manual, knowing how to DRIVE it would be by far the cheapest and best. hell even an auto there's a few trick sto get the best launch.
Old Apr 11, 2003 | 09:12 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
driving technique is not a mod
Old Apr 11, 2003 | 09:32 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
it is for Russ anything he drives, automatic 10s, no question!!!
Old Apr 11, 2003 | 09:33 AM
s9am_me's Avatar
whats a good intake filter to replace the stock air box?? the JWT pop charger seems a little on the high side or would it be better to replace the whole piping?
Old Apr 11, 2003 | 01:32 PM
One good one that I know of by experience is the K&N cone air filter. It added a noticealbe amount of horsepower and all you have to do is " recharge " or clean it every now and then? I'm not sure on the exact mileage of when to clean it?
Old Apr 11, 2003 | 01:37 PM
derrick's Avatar
i went with a k&n filter and custom adapter to fit it on.. good mod... moderate price for good results.. you could go with a cheaper filter.. but i trust k&n's quality
Old Apr 11, 2003 | 01:39 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Apr 12, 2003 | 01:12 AM
s9am_me's Avatar
did you buy that custom adapter? or made it yourself?
Old Apr 12, 2003 | 07:08 AM
NismoDrew91SE's Avatar
normaly the kit comes with the little metal plate you just screw in.
Old Apr 12, 2003 | 08:00 PM
derrick's Avatar
at first i used an adapter from a 91-96 300zx but it didn't fit right and had a 4" opening (ours run on 3") so i made a custom one out of the old air box... but i recently ordered a k&n filter from warpspeed and dallas just threw in an adapter for me.
Maxboy23
55
May 1, 2025 06:09 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
dvcamp
Sep 18, 2015 10:17 AM
