Questions about spring wrap...
Hey guys I am redoing my suspension tomorrow so I would appreciate it if I could have this info sometime tonight.
1. Has anybody ever had any problems with the plastic Radio Shack spiral cable wrap? (Lime's idea
) It seems like it would break under the pressure of the spring.
2. Should I wrap only the top and bottom coils or all of them? The only problem I see with wrapping all is that it would really reduce suspension travel since each coil would be so much wider.
3. What else do you guys use as spring wrap? Any comments?
Thanks,
-Cyrus
) It seems like it would break under the pressure of the spring.2. Should I wrap only the top and bottom coils or all of them? The only problem I see with wrapping all is that it would really reduce suspension travel since each coil would be so much wider.
Thanks,
-Cyrus
Originally posted by gtr_rider
http://www.vqpower.com/v2/modules.ph...howpage&pid=11
I'm not sure if that makes a difference.-Cyrus
Originally posted by Vyrus
Good stuff Luke, the only problem is that he used vinyl whereas I am using plastic.
-Cyrus
Re: Questions about spring wrap...
Rear - Only the bottom coil.
Thanks,
-Cyrus
If anyone is interested, logically, you can argue that wrapping more coils would NOT reduce suspension travel, but would not affect it at all! Suspension travel is from the bump stop at the top of the strut shaft to the bottom lip where the shaft enters the strut assembly.
Wrapping the coils with more spring wrap would actually INCREASE spring rate very slightly, since the coils will bottom out (deaden) sooner, and thus, you have less ACTIVE coils, meaning a stronger, stiffer rate.
Much of my logic is based off of this website:
http://www.stockcarproducts.com/spgtech.htm
hope that helps future searchers
i agree. wrapping the coils would slightly increase the diameter of the spring, but the inner coils do not touch and rub like the outter coils do. thus they can stand to be a bit wider all around.
something tells me to use a softer material for the wrap rather than something a bit stiffer. the softer may be less brittle and less likely to crack or shatter when being pinched with extreme force. OEM would probably be your best bet...
EDIT: wow, just realized the 2.5 year bump. he's probably already gotten around to that suspension install, right?
imported_Nismo_max
Feb 17, 2016 03:39 AM
pears
Sep 18, 2015 05:25 AM
