Dyno questions?
Dyno questions?
I had my car dynoed before the Y and B pipes on my 2k2 auto. I want to get the after dyno numbers. The place I originally dynoed at is very far away and thus a problem sneaking out of work. They have a DynoJet model 428C. AutoThority which is very close to me has this dyno: http://www.autothority.com/dyno.htm
Should I take the car back to the original place or to AutoThority. I want the most accurate numbers obviously. Thanks in advance.
Re: Dyno questions?
I know, but AutoAuthority's dyno is the same price and the unit is supposidly much better.
You've got to use the same machine. It's a tool to measure gains and losses and you'll never get an accurate comparison using a different machine when you're talking about such low power adding modifications.
Dave
Dave
I went back to the same place as the first time. The temp was about 25-27 degrees higher this time. I pulled about 5 more hp and 6 more tq. Do you post the SAE numbers or the uncorrected numbers from the DynoJet?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
