What size of pulley for Newbie SC
Hello!
I am going to order my new SC pretty soon. I would like to know that what size of the pulley I should use. I have 98 Auto upgrade with most thing except DON VB mod, I had Transmisiion cooler and oil coller installed already. I don't want to push my car too hard and I want to use it last long with SC. What else that I should upgrade for my car and what size of pulley I should use? Oh! Is there any problem that I can expect to have after installing SC ?
Re: What size of pulley for Newbie SC
Originally posted by YUTAKARNB
Hello!
Hello!
stock pulley 6psi, I believe 3.33 up to 8psi 3.25 pulley up to 10PSI
just order some metal ASP pulleys and a BOV and youll be alright
you can go with smaller pulleys like 3.25, 3.125 and adjust your boost with the BOV.
Re: Re: What size of pulley for Newbie SC
Originally posted by [maxi-overdose]
[B]
[B]
Re: Re: Re: What size of pulley for Newbie SC
Originally posted by PiotrC70
Curious?? Adjust your boost w/ your BOV??? loosening the BOV so it leaks boost? Isn't that pointless of getting a smaller pulley?
of course you dont want to start with a peak boost of 13 psi. so you can start with a small pulley loose the bov to 9 psi. Once you are sure that your car is ready for more...all you have to do is tighten the BOV a little bit more.
not pointless at all...unless you love to do pulley swap.
Re: Re: Re: Re: What size of pulley for Newbie SC
If you have a pull type BOV like HKS SSQ, and Apex twin chamer, I don't think loosening it will make a difference. My BOV are heard at 4psi and their really heard at 15. So your method wouldn't really work w/ certain BOV's Even on the loosest setting, my HKS will still hold over 15 psi. BTW, I have HKS SSQ's
Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Understandable... I've just NEVER heard of that approach before.
It took a lot of time to change the pulley and Y2KevSE decided to use a small pulley so I can play around with the amount of boost. With a small pulley, you boost faster and earlier. I dunno if my car is ready to handle more thatn 10psi.
there is a amount that you can let go. I wont try to aim for 6 psi with a 2.87 (default 13psi).
one of the downsides is our V2 s-trim can only handle certain pulleys. V2's max impeller speed is 50,000 rpm. I think 2.87 is already passing its limit after 5000 engine rpm.
btw, I have a simple BOV, greddy.
Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
you are right and it only works for certain BOV.
Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Originally posted by max'n out
the 2.87 at 6200 rpms, it's just over the writen limit...but it does handle it just fine. The v1 is teh same way...You really want boost upgrade teh blower to the SQE trim it has a 62000rpm impeller limit.
Originally posted by GoldenGlory
help me do this
please
help me do this
please
so how much does it cost to upgrade the blower to SQE trim?
Craig : v1 and v2 s-trim both have the same limit, 50k. I agree with you....smaller pulley means adding more work to the blower.
GoldenGlory : ?? you want me to change your pulleys?
Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
the limit for the blower is 50k. I think with our crank pulley diameter, it passes the limit at 5000 engine rpm IIRC. I lost the link to the thread.
Check the numbers.
Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Limit is 50k, absolute limit is 53k, and it only hit that just about at shift.http://www.vortechsuperchargers.com/...rformance.html
Check the numbers.
Check the numbers.
do you have the diameter of our crank pulley?
I remembered that I use this
http://www.vortechsuperchargers.com/...pspeedv-2.html
to calculate the impeller speed. It maxed out at 5300 engine rpm.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
thx
thx
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
6.25 in the iner diameter that matters. And the 2.87 clearly works I have it , kev had it, and others have it.
thx~
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
I think I got a right crank diameter somewhere and the calculation was wrong.
thx~
thx~
shift point of 6200-6300
supercharger pulley of 2.87
impeller speed at the outside is
50690.-- within the 53000 maximum limit.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
crank pulley of6.25 inner and or 6.5 outter
sorry~ I meant I got a wrong diameter from somebody
knight_yyz
Nov 1, 2015 01:34 PM
Sometimes the auto doesn't shift that early.
