What size of pulley for Newbie SC
Old Apr 16, 2003 | 03:10 AM
YUTAKARNB's Avatar
Hello!
I am going to order my new SC pretty soon. I would like to know that what size of the pulley I should use. I have 98 Auto upgrade with most thing except DON VB mod, I had Transmisiion cooler and oil coller installed already. I don't want to push my car too hard and I want to use it last long with SC. What else that I should upgrade for my car and what size of pulley I should use? Oh! Is there any problem that I can expect to have after installing SC ?
Old Apr 16, 2003 | 04:11 AM
JAY25's Avatar
Re: What size of pulley for Newbie SC
Originally posted by YUTAKARNB
Hello!
stock pulley 6psi, I believe 3.33 up to 8psi 3.25 pulley up to 10PSI
just order some metal ASP pulleys and a BOV and youll be alright
Old Apr 16, 2003 | 06:10 AM
[maxi-overdose]'s Avatar
oh yea~ several for my install. Glad my installer helps me out a lot. Make sure you have extra time for trouble shootings.
you can go with smaller pulleys like 3.25, 3.125 and adjust your boost with the BOV.
Old Apr 16, 2003 | 10:15 AM
PiotrC70's Avatar
Re: Re: What size of pulley for Newbie SC
Originally posted by [maxi-overdose]
[B]
Curious?? Adjust your boost w/ your BOV??? loosening the BOV so it leaks boost? Isn't that pointless of getting a smaller pulley?
Old Apr 16, 2003 | 10:53 AM
BlackCat's Avatar
RIP '98 Maxima SE
Although you can run without the VB mod you should get it soon.
Old Apr 16, 2003 | 01:10 PM
Re: Re: Re: What size of pulley for Newbie SC
of course you dont want to start with a peak boost of 13 psi. so you can start with a small pulley loose the bov to 9 psi. Once you are sure that your car is ready for more...all you have to do is tighten the BOV a little bit more.
not pointless at all...unless you love to do pulley swap.
Old Apr 16, 2003 | 01:42 PM
PiotrC70's Avatar
Re: Re: Re: Re: What size of pulley for Newbie SC
Understandable... I've just NEVER heard of that approach before.
If you have a pull type BOV like HKS SSQ, and Apex twin chamer, I don't think loosening it will make a difference. My BOV are heard at 4psi and their really heard at 15. So your method wouldn't really work w/ certain BOV's Even on the loosest setting, my HKS will still hold over 15 psi. BTW, I have HKS SSQ's
Old Apr 16, 2003 | 02:05 PM
max'n out's Avatar
You want the 2.87
Old Apr 16, 2003 | 02:12 PM
Re: Re: Re: Re: Re: What size of pulley for Newbie SC
you are right and it only works for certain BOV.
It took a lot of time to change the pulley and Y2KevSE decided to use a small pulley so I can play around with the amount of boost. With a small pulley, you boost faster and earlier. I dunno if my car is ready to handle more thatn 10psi.
there is a amount that you can let go. I wont try to aim for 6 psi with a 2.87 (default 13psi).
one of the downsides is our V2 s-trim can only handle certain pulleys. V2's max impeller speed is 50,000 rpm. I think 2.87 is already passing its limit after 5000 engine rpm.
btw, I have a simple BOV, greddy.
Old Apr 16, 2003 | 03:04 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
What about the V1? Can it spin faster? Is it built stronger?
Old Apr 16, 2003 | 03:24 PM
max'n out's Avatar
the 2.87 at 6200 rpms, it's just over the writen limit...but it does handle it just fine. The v1 is teh same way...You really want boost upgrade teh blower to the SQE trim it has a 62000rpm impeller limit.
Old Apr 16, 2003 | 04:01 PM
Craig Mack's Avatar
Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Keep in mind that whatever you do, the smaller pulley you run, the faster you will wear out the blower.
Old Apr 16, 2003 | 10:38 PM
GoldenGlory
[B]
help me do this
please
Old Apr 17, 2003 | 06:04 AM
PCGuRu2K's Avatar
Originally posted by GoldenGlory
help me do this
please
Switch it to the HKS.. Did mines last weeks.. Sounds a lott better then the Blitz. You still have that one right?
Old Apr 17, 2003 | 08:02 AM
the limit for the blower is 50k. I think with our crank pulley diameter, it passes the limit at 5000 engine rpm IIRC. I lost the link to the thread.
so how much does it cost to upgrade the blower to SQE trim?
Craig : v1 and v2 s-trim both have the same limit, 50k. I agree with you....smaller pulley means adding more work to the blower.
GoldenGlory : ?? you want me to change your pulleys?
Old Apr 17, 2003 | 09:20 AM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Limit is 50k, absolute limit is 53k, and it only hit that just about at shift.http://www.vortechsuperchargers.com/...rformance.html
Check the numbers.
Old Apr 17, 2003 | 09:37 AM
Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Check the numbers.
thx
do you have the diameter of our crank pulley?
I remembered that I use this
http://www.vortechsuperchargers.com/...pspeedv-2.html
to calculate the impeller speed. It maxed out at 5300 engine rpm.
Old Apr 17, 2003 | 10:14 AM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
thx
6.25 in the iner diameter that matters. And the 2.87 clearly works I have it , kev had it, and others have it.
Old Apr 17, 2003 | 01:57 PM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
I think I got a right crank diameter somewhere and the calculation was wrong.
thx~
Old Apr 17, 2003 | 02:02 PM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
thx~
crank pulley of6.25 inner and or 6.5 outter
shift point of 6200-6300
supercharger pulley of 2.87
impeller speed at the outside is
50690.-- within the 53000 maximum limit.
Old Apr 17, 2003 | 02:06 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Sometimes the auto doesn't shift that early.
Old Apr 17, 2003 | 02:11 PM
sorry~ I meant I got a wrong diameter from somebody
Old Apr 17, 2003 | 03:38 PM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What size of pulley for Newbie SC
Mine does It always shifts exactly when it should.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
