Polished Wheels
Old Apr 16, 2003 | 08:41 PM
Karmapolice's Avatar
Polished Wheels
Has anyone polished their factory wheels?? If so do you have any pics? I was thinking of doing this but was wondering if it was worth all the work. The clearcoat is coming off of my rims and looks loike crap.
Old Apr 16, 2003 | 10:41 PM
D-sta's Avatar
Re: Polished Wheels
MAX420 (no longer a member) did it and I saw it in person and it didn't look that good. Probably where he took it wasn't a good place either. Not too many other members here with chrome stockers.
Old Apr 17, 2003 | 05:38 AM
DaBoxSE's Avatar
Re: Re: Polished Wheels
Whats happened to Max420?
Old Apr 17, 2003 | 06:36 AM
D-sta's Avatar
Re: Re: Re: Polished Wheels
Sold his max and bought a camaro.
Old Apr 17, 2003 | 09:08 AM
Walka's Avatar
it looks nice, but not worth the time and effort.
before:
after:
Old Apr 17, 2003 | 10:27 AM
Maximan190's Avatar
Re: Re: Re: Re: Polished Wheels
a real camaro i hope..
Old Apr 17, 2003 | 11:12 AM
crazy4maxima's Avatar
before:
after:
how ?? write up.. please... damn that looks nice.. but that means have to leave yor center caps off... cuz you cant polish that right???? anyway how can you polish your rims like that.. how much grip paper??? how must know.. and how long did it take
Old Apr 17, 2003 | 03:32 PM
lowmax4's Avatar
I friend of mine used a buffer on his wheels with some type of buffer stuff(it was liquid) and that worked good but it's gonna be hard to get in between the spokes
Old Apr 17, 2003 | 05:22 PM
BensMax93's Avatar
damn, that looks nice!! how would you go about doing that??? someone fill me in please!!
Ben
Old Apr 17, 2003 | 05:59 PM
xsohaib's Avatar
Ben
me too very ineterested in a write up!
Sohaib
Old Apr 17, 2003 | 07:57 PM
MaximaBalla's Avatar
Yeah, I too think that it looks good! The only problem as said is that you'd have to leave your center caps off unless you spray painted it or something? I don't know?
Old Apr 17, 2003 | 09:03 PM
Walka's Avatar
thanks for the compliments.. wish i had the time and energy to do the other 3 wheels.
first i got a power drill and bought a foam applicator pad attachment that accepts peel and stick sanding discs. like this one:
then i got plenty of sanding discs as i could, in as many grits as you can find. get the peel and stick kind, real easy to change:
i cant remember what grits i used.. but i know i went to all the stores and found the discs in as many grits as possible. when sanding, its important to start with something real coarse to make sure you remove all of the imperfections. then you gradually move towards finer and finer grits. each grit will make the sanding become finer and finer, until eventually all of the sanding marks are gone. unfortunately, they dont make sanding discs in very high grit papers.. or at least no store around me carried them. so what i did was, i finished with my finest paper and switched to an orbital buffer and buffed with rubbing compounds for a REEEEEAAALL long time. just like the sand paper, you move up to something finer. i went from real coarse stuff rubbing compound to a mild rubbing compound to a really fine polishing compound. the thing to remember with sanding.. the more grits you have, the better it will be in the end. eventually, your finer grit stuff will take out all of the sanding marks and give you a smooth finish. when i was happy with the finish, i polished the **** out of the wheel with some metal polish. when satisfied, clear coat if you want. clear coat will take away from your shiny finish though, unless you know how to spray them correctly. if you choose not to coat them, remember, wheel cleaners and such will do damage to bear alloy aluminum (like our wheels).
as far as the buffing goes, use a buffer and not your power drill. the rpms on the drill is way to high and it will tear apart your terry cloth bonnet that you will be buffing with.
also, when sanding metals, its important to get a face mask. you cant inhale metal shavings. not healthy. while im on the subject of health, you may want to get a pair of earplugs, or if you are ghetto, a big set of headphones. since you will be buffing and power sanding for a LONG time, and i do mean long, you may want to protect your ears, unless you like them ringing for days.
the center caps, toss em. its a plastic cap with metal foiling, you will need new oem ones.
like i said, this aint no easy task. thats why i havent gotten around to the other 3 wheels. this method doesnt apply just to wheels, you can do it to anything metal if you want. depending on how much time you put into it, you can get you stuff as reflective as a mirror. our wheels are easier to do than most others because the outside face of the wheel is perfectly flat. its nearly impossible to polish the inside of those tiny spokes.
one more note, remember to keep the sanding disc/buffer pad flat when working. if you lift up and sand/polish with the sides or edges, your drill or buffer may skip or jump which might cause a knick or damage to the alloy aluminum. aluminum is a soft metal, so its easy to knick it with a out of control tool spinning at 3500-5000 rpm.
good luck.
walka.
Old Apr 17, 2003 | 09:11 PM
Walka's Avatar
progression shots.
Old Apr 17, 2003 | 09:12 PM
Walka's Avatar
progression shots.
Old Apr 17, 2003 | 09:14 PM
Walka's Avatar
progression shots.
Old Apr 17, 2003 | 10:01 PM
pezking4's Avatar
Just imagine doing the little slots on the SE wheel
Old Apr 17, 2003 | 10:11 PM
yeah i got se and gxe rims
Old Apr 18, 2003 | 05:27 AM
e_is_chillin
Re: Polished Wheels
If you like, do what I did to mine.
Old Apr 18, 2003 | 10:16 AM
Well what did you do??
Old Apr 18, 2003 | 10:34 AM
Michael's Avatar
Back in a 3rd Gen.
replaced them with something else
Old Apr 18, 2003 | 12:45 PM
I wish I had the cash.
Old Apr 18, 2003 | 01:24 PM
Michael's Avatar
Back in a 3rd Gen.
I was just joking he actually polished his. Check out his home page.
Old Apr 18, 2003 | 03:06 PM
It wont open for some reason. I thought maybe he did something a little diffrent.
Old Apr 18, 2003 | 03:36 PM
Michael's Avatar
Back in a 3rd Gen.
try this
http://maxima.cardomain.com/id/e_is_chillin
Old Apr 18, 2003 | 05:35 PM
I guess its sandpaper and water for me. Along with a little mothers polish. Can't look any worse. I thought I'd use some stripper first to remove the clearcoat. After I'm done I'll try to post some pics.
Old Apr 18, 2003 | 08:39 PM
e_is_chillin
Sry you had trouble loggin in. Hope it works out for you. I had them that way for a few years. Mothers Aluminum polish worked wonders for a shine, but it takes a toll on your hand (rubbing) lol Peace.
Old Apr 18, 2003 | 10:40 PM
«§»Craig B«§»'s Avatar
take the "www" out of the link and it'll work like awsm66 said
it's just http://maxima.cardomain.com/id/yournamehere
sorry about your spoiler
Old Apr 19, 2003 | 12:03 PM
Walka's Avatar
dont bother trying to remove the remaining clearcoat first with some sort of laquer thinner.. just a waste of time. the sanding will chew right through it all with ease.
Old Apr 19, 2003 | 01:47 PM
cool thanks, any Idea what grit should I use??
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
followthadollar
Sep 23, 2015 08:31 PM
