Autometer Oil Temperature Sender Problem...
Last night I did the plumbing and hooked up my Oil Pressure sender and Oil Temperature sender.
After doing so the pressure guage works just fine, but the temperature guage doesn't budge!
I "inlined" everything between the oil feed line to the Supercharger and the supercharger...functionally speaking like this:
There isn't any trick to the temp sender that I'm missing, is there? The guage has power and ground, and the signal wire runs straight from the end of the temp sender to the guage. The sender should be grounded through the SC (as the pressure sender is).
Am I missing something stupid?
I hope to post a pic later tonight...this setup is really ugly!
Code:
SC PRESSURE SENDER | | |-----------| | | OIL TEMP SENDER
Originally posted by redmaxpa007
are you using the stock temp sender or are u using the autometer one?
There's no circulation of oil in the way you hooked up the sender in the dead end there... The heat would mostly get to the sender portion thru conduction. It should move after some driving though.
hmm are you sure the sender is grounded?
Unless the pressure sender doesn't require ground...but I'm pretty sure it does.
Originally posted by ejj
The autometer pressure sender is working perfectly. IIRC it requires a ground as well, and would get it through the SC.
Hmm, good point. It doesn't move after 10 minutes of driving or so. Maybe I have to re-think its location.
I'm puzzled about why you're not getting any signal at all, though. Even though you don't have oil directly in contact with the sender, it still should be registering some temperature gain from diffusion of heat into the tee.
Back when I had an auto tranny, I had my oil temp gauge set up to measure transmission fluid coming from an external cooler. The sender teed into the rubber hoses, so I had to run a grounding wire from the sender to the engine block. You might try that just to be absolutely sure it's not a grounding issue. (For instance, if you used Teflon tape maybe you've insulated the sender from the grounding path.)
Originally posted by Stephen Max
I have my oil temperature sender in my oil drain plug. Works great in that location, but it would be nice to know the oil temp going into the blower, like you're trying to do.
If moving its location doesn't fix it, I'll try grounding it as well.
I had a bunch of stops to make on my way home from work today, and all in all was driving for about an hour.
The guauge showed almost 125 when I got home, so it is working, its must just be the location that's causing the problems.
What are normal temp readings?
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Oct 28, 2019 10:58 PM
05RLS2
Apr 14, 2016 11:49 AM
