Sway bar bushings
Old Apr 20, 2003 | 08:59 PM
Tom's Avatar
Tom
Sway bar bushings
I would like to get some polyurethane bushings for replacement. Energy Suspension came to mind, but they didn't have one specific to the 3rd gen.
Any ideas where I can get a replacement set? Thanks,
Old Apr 20, 2003 | 09:07 PM
Matt93SE's Avatar
STFU n00b!
energy makes some that go on the suspension techniques sway bar... I believe the bushings are the same size, and since they bolt into the same place, I would assume they will fit on the OE sway bar..
see what you can find for the ST sway bar set...
btw.. if you're still running the factory sway bars, I highly suggest getting the Addco rear or the Sus Tech front and rear set. makes an amazing difference in handling.
Old Apr 20, 2003 | 09:41 PM
«§»Craig B«§»'s Avatar
I dont know about the other pieces, but I have a set for the front sway bar endlinks (aka connecting rods). They're Energy Suspension generic import sized ones that I got at PepBoys - about $8 for a pack of 8, but you'll only need 4 for fronts. The inner diameter would be nice if it were about 1mm larger. It's a tight fit but still works fine.
Part Number is 9.8105GC
Old Apr 21, 2003 | 03:38 PM
Lordrandall's Avatar
Or you can call Kaleb at Courtesy, and tell him you want Energy suspension endlink bushings for the FSB.
www.courtesyparts.com
Matt is right tho, get an Addco RSB at the least.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
