question about sc install ?
Old Apr 23, 2003 | 01:35 PM
mark w chrzanow's Avatar
Is the cam sensor retainer plate a must for a install on a 96 max.
The part seems to be missing out of my kit, but I was told it will
work with out the plate?
I am told the plate moves the sensor 45 degress out of the way of
the blower?
mark
Old Apr 23, 2003 | 01:38 PM
Latinmax2
I don't know about the 95 but I think it is needed.
Old Apr 23, 2003 | 01:52 PM
delio's Avatar
No you don't need it... you can wiggle it in there... MardiGras doesn't have it either.
Old Apr 23, 2003 | 01:55 PM
even on a v2
Old Apr 23, 2003 | 07:58 PM
delio's Avatar
Originally posted by mark w chrzanow
even on a v2
That shouldn't make a difference in all honesty... it may be tight, but it will fit
Old Apr 23, 2003 | 09:03 PM
BippuBenji's Avatar
Ok another question, the sleeve that you hammer into the pulley without rails, does the sleevecome with the kit or is it removed from the factory idler pulley?
-Ben
Old Apr 24, 2003 | 06:26 AM
JAY25's Avatar
-Ben
while the plate is off place the pulley and the sleeve onto the plate as if you were going to install it and place the 19MM and start tigtening it down it will compress the sleeve into the pulley. Thats what I did
Old Apr 24, 2003 | 06:53 AM
ejj's Avatar
ejj
-Ben
It comes with the kit. Should be in the bag with the idler pully.
Old Apr 24, 2003 | 07:42 AM
Stephen Max's Avatar
Neither do I. I mounted my blower bracket without disconnecting the cam sensor harness, so that the bracket presses the harness against the timing case. No problems so far.
Old Apr 24, 2003 | 09:53 AM
BippuBenji's Avatar
Ok this sucks, I don't happen to have the sleeve in my ider pulley bag. I'm probably blind, but I can't seem to find that part in the Part Number sticky in this forum, does anyone know hte part number on that sleeve? Thanks.
-Ben
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
