Threads on Oil Pan Stripped?
I am having one hell of a time trying to get the oil drain plug out. I tried using a small ratchet to get it undone but it won't budge. A ratchet should be enough shouldn't it? Now I am thinking maybe the threads on the pan are stripped? I don't want to take out the plug with a stripped pan or my car won't be able to go anywhere. How can I tell for sure and what should I use to get it loose?
Re: Threads on Oil Pan Stripped?
Just remember when you put it back on not to do the same as the previous individual did.
The head is 14 mm for the 4th gen. I think it's an 8mm diameter bolt. A new bolt, unstripped with copper gasket is reletively cheap. I replaced mine at about 96,000 miles. I've never needed anything but a standard wrench to get it loose. If the head is stripped get a new one at a local dealership or autoparts store. Then remove the stripped bolt with a vise grip plier.
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
Could also put a steel pipe or equiv. on the handle of your 3/8 ratchet. Good luck.
