Went to the track again (13.91 and 103.48)
Went the track again last night. Hoping to improve on my 13.99@100.0 that I put up last time. I was aiming for 13.8's
This time I used my 17" Rota's with 225/45/17 Kumho 712's in the front, as I was too lazy to swap the stock wheel/tire combo back on the car. This may not have been a bad thing.
My best ET:
So close to 13.8, yet so far away.
Best Trap:
I didn't really do anything different between the two runs. Very similar launches, etc. I still took it a tad easy shifting in fear of tranny damage.
I would think with a 103 trap speed I should be able to get 13.8's easy, however I don't think I'm going to do better than my 2.23ish 60' on street tires.
We had an all maxima.org final in the import division bracket racing. Maksim2000 and I. I cut a .499 RT and redlighted. You would think they'd consider that close enough!
Anyways, MEVI is in the mail! I'm aiming for 13.7's with it, then I've gotta get this damn clutch installed so I can put a smaller pully on there!
My best ET:
Code:
60': 2.234 330': 6.035 1/8: 9.088@81.14 1000': 11.699 1/4: 13.918@100.28
Best Trap:
Code:
60': 2.296 330': 6.113 1/8: 9.182@80.95 1000': 11.783 1/4: 13.988@103.48
Originally posted by Nealoc187
How the heck did your trap speed go up 3mph if you didn't do anything different. 1/8 traps are about the same. That's weird.
how much different is the overall diameter of the tires you used on these runs vs. the previous runs? that and the weather could have some effect on your 3mph gain.
--Paul
--Paul
--Paul
--Paul
That's not the point. The two runs I listed above are on the same day, both last night. Tires and weather aren't part of the equation.
Originally posted by ejj
225/45/17's VS 215/55/16's
--Paul
that difference in trap speeds is quite baffling.
I just noticed that my 1/8 trap was LOWER on the run that I trapped 103 than the 100 run...I can't imagine how I'd pick up almost 3.5 extra mph in the top 1/8...
Wish I knew what I did...I'd do it every time!
Originally posted by Street Reeper
Awesome times, I looked on your websight for your previous times and what kind of tires your using but it is "coming soon" could you fill me in on the times and tires?
NA I ran a 14.54@95ish on 225/50/16 Nitto DR's
NOS 70 shot I ran a 14.07@99ish with the same DR's.
LOL. That's been "coming soon" for quite a while now. Don't know when I'll get to it.
Then you pulled a 13.91 with 17 inch wheels, and Kumho's, I may have to look into getting Kumho's if that is the case.
Did you run the previous 13.99 @ 100 with the Nitto's (15inch stock wheels?) with the same mods you have now,
The better 60' times could have been because of more rubber in the track, as my 13.99 was the first weekend the track was open, and it was quite green.
However, I've noticed that with 17's (both on this car and my old one) I tend to trap a lot higher. I'm going to have a difficult time getting of the line no matter what (until I get slicks), so I figured upping my top end couldn't hurt!
In car video:
http://www.ericj.org/maxima/img/RideAlongWithEJJ.mpeg
That wasn't a good run. I think something like 14.1@102.
In car video:
In car video:
In car video:
In car video:
I was out at the local races a couple of weeks ago and saw a guy with a blue 02. He said it was a 13 second car because he had a taken the car and a stop watch out to the highway and observed how fast it was to the markers.
He drove a Saturn with neon all over it and a straight pipe, the max was a rental while it was in the shop which explains a lot.
Originally posted by Dave B
As for the trap speed difference, possibly it's related to some heat soak
or an ECU fluke (timing retard, rich, O2 fluke, etc)
Although, 100mph trap seems to be pretty normal for the stock pully. So, its like I added speed, not dropped it...
Maybe I didn't do well going in a straight line and made 1320 feet into 1330?
mkaresh
Mar 12, 2018 06:48 PM
