how to black out chrome window trim?
what are some good ways to black out the chrome window trim? i have a gle and the SE's have black as opposed to the chrome colored window trim. any suggestions of how?
My brother used electrical tape for his 4th gen accord. I was exactly the right length. When he told me about it I imagined it would look real ghetto, but it actually turned out pretty well and even lasted through a whole winter.
If you want to do it right follow the steps below (this is what I would do, follow at your own risk):
1) sand with at least 220 grit sand paper or finer. You will also want to do the other black trim (even what's on the c-pillar)
2) tape EVERYTHING around what you want to paint. Overspray will get everywhere.
3) spray all the black parts with a primer and let it dry
4) Spray with flat balck paint. Use a couple of heavy coats. If it runds, just sand the run and paint again. Krylon works good. I've been wanting to try that BBQ grill paint as it's supposed to withstand high heat (like from the sun).
5) Untape, pull up and away so as not to peel the paint.
6) You may have some overspray on the windows. If so, just use a fine steel wool (0000 or finer). Be sure to get all of the steel wool filings off the car (use an air hose). If they get wet they may rust.
If you have overspray on painted surfaces use mineral spirits to remove, but ensure to wipe away quickly. You may even want to wax that area, depending on how **** you are.
KISS - Keep It Simple Stupid
They make a product specifically for this and you can return it to stock if and when you sell.
i used a product called Trimbrite, ti is available at Autozone. Get at least three rolls,
D
D
D
Originally posted by RapidMax
Any pics? I checked your homepage but the only pick that looked like it was done was in the garage so you couldn't see too well. If it looks good I'm definitely going to do it. How much is it also?
It looks like it is supposed to. All the chrome is now black
D
just use the trimbrite stuff from autozone. make sure ya leave some overlap on the ends of the trims for shrinkage. thats the only thing i did wrong and still havent gotten around to fixin it. otherwise it looks great til ya get about a foot away from it. good luck
jsmith24
Feb 1, 2016 12:35 AM
brichi
Sep 14, 2015 05:23 PM
